Old 09-21-2004, 03:07 AM   #1
ScottH
ScottH's Avatar
What oil to use when starting a fresh motor?
What is the best oil, weight, etc. to use to break in a newly rebuilt engine? Any suggestions are appreciated.
Thanks.
ScottH is offline   Reply With Quote
Old 09-21-2004, 03:08 AM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i used castrol gtx 10-40
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 09-21-2004, 03:33 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
As long as it is detergent, and non-synthetic.
Old 09-21-2004, 03:37 AM   #4
ScottH
ScottH's Avatar
I thought I remembered someone saying a straight weight is best for breakin, but wasn't sure.
Old 09-21-2004, 03:42 AM   #5
incoma
incoma's Avatar
I always use 30W for the first hour, then swap to 10/40. I do this just to clean the engine out.
incoma is offline   Reply With Quote
Old 09-21-2004, 05:15 AM   #6
1972C10
1972C10's Avatar
I put 6 quarts of valoline 10W40 in mine and change it out at 500 miles then 3000 from then on.
I only overfill the engine by a quart the first time for break in.
1972C10 is offline   Reply With Quote
Old 09-21-2004, 08:57 AM   #7
'68OrangeSunshine
'68OrangeSunshine's Avatar
I'm breaking in my new 292 with 6 quarts of Napa straight 30 SAE non-detergent for the first 100 miles, then switching to detergent 30 weight. I will also add the 8 oz bottle of GM break-in oil (EOS).
Old 09-21-2004, 01:04 PM   #8
mrein3
mrein3's Avatar
That is what I was always told. Straight 30, non-detergent for cam break-in and 50 miles after that. Then switch to detergent straight 30. I then dump that at 500 more miles and switch to 10-30 for the rest of the engines life.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 09-21-2004, 01:10 PM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
Gm's EOS (engine oil suppliment) with your normal weight oil.
Keith
Convert to disc brakes.
Old 09-21-2004, 01:34 PM   #10
Joe67
67 is sold
I've heard it is best to use dino oil on a new engine, but then again the Corvette and exotics use Mobil 1 from the start with no issues
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 09-21-2004, 02:35 PM   #11
bigjimzlll
bigjimzlll's Avatar
vettes have roller cams. , I use store brand 30 weight and EOS//for the first 20 miles or 20 minuts,which ever comes first..then mobile one synthetic. If the rings are not seated by the time the cam is broke in..somethings wrong
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 09-21-2004, 05:10 PM   #12
inline6Bill
A classic GM kinda guy
Valvoline 30 wt with GM Engine oil supplement for the first 50 miles/50 minutes. 30 wt Valvoline, changed again @500 miles, 1500, then every 2000 to 3000 miles thereafter. One engine I have done this to just ticked over 150,000 since the rebuild. Can't complain about that.
Old school rap music: a dual exhausted GM 6 with no mufflers.
"If you can find a better vehicle, buy it" Lee Iacocca, Chrysler commercials of the '80s.
"I did. They are called Classic GM pickups !!!"
inline6Bill is offline   Reply With Quote
Old 09-23-2004, 12:19 AM   #13
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
10 W 30 Valvoline Never Had A Failure Yet???
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-23-2004, 07:47 AM   #14
gonebad2
Merciless Butcher
gonebad2's Avatar
Is there much value in using the GM EOS ? I have purchased several GM crate motors in the past and have been forced to purchase it when I purchase the crate motor by the GM parts guy. He says you won't get the warranty if you don't buy it. I have always dumped it in with the oil during the break in period. Just wondering??
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 10-04-2004, 07:42 PM   #15
sbc350gearhead
sbc350gearhead's Avatar
Never use a ND oil in a modern engine. They don't generally have the anti-wear and anti corrosion additives necessary to fully protect your engine. GM's EOS is loaded with anti wear agents, which may offset this to some extent........but there is just no reason to use a ND oil. Some very old engines with rope seals are not compatible with detergent oils, but these engines are few are far between.
sbc350gearhead is offline   Reply With Quote
