09-21-2004, 04:36 PM | #1 |
Difference in rad. supports ??
What is the difference in rad. supports for a non-air and an air truck, 1972?
Will a non-air support work and what will need changed or, should I just find an air support? Thanks.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
09-21-2004, 05:54 PM | #2 | |
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
09-21-2004, 06:02 PM | #3 | |
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
09-21-2004, 06:31 PM | #4 |
Senior Moment
How about from Chevy to GMC any differance
Dont mean to steal your post, its along the same lines
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
09-21-2004, 07:00 PM | #5 |
Custer had a plan too.
GMC supports have two headlight buckets on each side instead of one.
09-21-2004, 07:09 PM | #6 |
How about years? Both Chev & GMC
Saskatoon, Saskatchewan Canada |
09-21-2004, 07:59 PM | #7 |
67/68 Chevy supports have seven holes along the bottom edge facing out. 6 are used for the lower shield/deflector, the 7th is for the hood release support. 69-72's only have the 1 hole for the release support.
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" |
09-21-2004, 08:31 PM | #8 |
So can someone tell me and/or post pics on the correct hole sizes and which is which?
Thank you John for the info. If a Greenlee will work, that would make it easy and clean. Obviously I have a non-air truck and want to add air. Although it will be an aftermarket setup, I would think that I will need those holes.
09-21-2004, 09:38 PM | #9 |
member #16
The hole size is 1 1/2". I have a pic which shows the locations pretty good. I dont think we can post pics yet, if you like I can E Mail it. As mentioned before the holes have a dimple to locate them. John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 09-21-2004 at 09:40 PM. |
