Old 09-21-2004, 05:04 PM   #1
ScottH
ScottH's Avatar
Steering column cup replacement
I have a 72 with a 3-on-the-tree. The problem I have (well, this one anyway) is the hole which holds the shifter arm in place is extremely worn, so the pin (larger, wrong one) is loose as is the shifter arm. I was thinking of replacing the section of column (I'll refer to as the cup) on which the shifter arm attaches.
Can anyone give me an idea of what is involved with dis-assembly of the column to replace the cup section?
Any info or suggestions are appreciated.
Thanks.
ScottH is offline   Reply With Quote
Old 09-21-2004, 07:15 PM   #2
68C15
blood type; Retumbo
68C15's Avatar
never been in one before but if you send me pics I will try to help.
kyle5498@msn.com
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 09-21-2004, 09:01 PM   #3
71swb4x4
71swb4x4's Avatar
It really isn't too tough. The assembly manual says you need some special tools but I haven't had any problems without them.
I can email you the pages of the assembly manual tonight if you would like them. You should get yourself one when you can. They are very nice to have around.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-21-2004, 09:12 PM   #4
ScottH
ScottH's Avatar
Thanks guys....71swb4x4, if you could email me the pages I would greatly appreciate it. Sure sounds like I need to get that manual.
Scott
Old 09-21-2004, 11:41 PM   #5
71swb4x4
71swb4x4's Avatar
If the cup is the same on an automatic I have one in very nice shape.
I will go get those pages for you now.
Old 09-21-2004, 11:58 PM   #6
71swb4x4
71swb4x4's Avatar
I scanned 2 pages. It won't let me post them. I can email them to you. Email me at shawnstorhaug@hotmail.com and I will reply with the 2 pages.
Shawn
Old 09-22-2004, 12:29 AM   #7
Plain 72
The automatic and the standard are different. I tried using a lever from an automatic in my truck, it will work, but it is thinner than the standard shift. Knowing this, I would think the cups are different also. I friend of mine ordered me a new cup for my three on the tree, so new ones must be available.
1972 1/2 ton 4x4
1995 S-10 (Gas Saver)
1998 Caravan (Wife's)
Plain 72 is offline   Reply With Quote
