Old 09-21-2004, 05:33 PM   #1
Yukon Jack
Post Whore
Yukon Jack's Avatar
Steering column problem
In this pic of the steering column on my 70 K5 the area indicated by the area should be about 1" up. I was told this is the a race and there should be bearings.
Does anyone know what is involved in repairing this problem?
Am I correct in assuming the vehicle shouldn't be driven with this problem?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-21-2004, 05:37 PM   #2
landon4421
Life is Good !
landon4421's Avatar
Picture is kind of dark. But I would say you could probally drive it ! Hell I have for a few months now ! I would like the answer to this question as well !
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 09-21-2004, 05:42 PM   #3
ljbear
ljbear's Avatar
Mark,
There is supposed to be a bearing there. Still available through GM, part #3981935, about $25 retail. I think it's also available aftermarket. Driving that way probably isn't the best/safest thing, but I've seen many like that going down the road.
I stood outside last night waiting/listening for that thing to fire, looks like it may be cold this weekend
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
"Don't confuse enthusiasm with capability"
ljbear is offline   Reply With Quote
Old 09-21-2004, 05:50 PM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
Dang battery was too dead to fire the engine - will be picking up a replacement today, yep, it looks like it may be a cold weekend, well, cold for me at least!
Old 09-21-2004, 06:04 PM   #5
cdowns
cdowns's Avatar
hard to tell with the picture being so dark(a cheap clamp anywhere lamp makes pictures better) but yes there's supposed to be a bearing there and there's also supposed to be a spring above the clamp that holds the steering column to the intermediate shaft
Old 09-21-2004, 06:31 PM   #6
71swb4x4
71swb4x4's Avatar
I started reassembling my column last night, and there should be a metal retainer held on by a clip, then the bearing, and the bearing should be seated into a large plastic seat. It is real easy to replace.
I have the instructions in my assembly manual if you need them.
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-21-2004, 07:51 PM   #7
ljbear
ljbear's Avatar
I'm not sure, but I think the tilt column end has the metal cup and retainer clip you're talking about. As Cdowns mentioned the standard column pictured uses a large washer and spring to keep the bearing in place.
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
Old 09-21-2004, 08:59 PM   #8
71swb4x4
71swb4x4's Avatar
You are right, I didn't even think about that. I should have paid more attention to the other replies.
Old 09-21-2004, 09:53 PM   #9
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here's a lightened up photo - this is a photo I took of the engine compartment when I wasn't aware of the problem.
Old 09-21-2004, 09:54 PM   #10
Yukon Jack
Post Whore
Yukon Jack's Avatar
I have a three speed manual column I can probably grab parts off of to make this one work - this manual column is for a 4 speed on the floor.
Old 09-21-2004, 10:04 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Lots of trucks are like this, there really is no danger in driving it. The steering wheel is still hooked to the gear box with a metal shaft.
