09-22-2004, 01:12 AM | #1 |
Crazy L You Have A Pm
Pm From Gmc67swb
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd |
09-22-2004, 06:38 AM | #2 |
Fabricate till you "puke"
CTF-DF148552 on the clutch/ press plate. CTF-N1716, on the throwout bearing. You might check with centerforce tech to be sure on that bearing....i did run into a minor problem on how it fit the fork. the groove was a little narrow, & I dressed the fork on the grinder to let it "float" properly. the tech guy at centerforce had another pn for the bearing(to fit the cast fork), but it was not listed on Summit's site. There was no diff in height on the bearing, but just a little diff in the groove width.... 060 off the fork, & I was good to go. best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
