Old 09-22-2004, 02:14 AM   #1
shortymac83
hmm...
shortymac83's Avatar
removing stuff from under cowl vent?
OK, on my 67, it was parked under a pine tree for 8 years, and as a result, there are pine needles everywhere. Including down in the cowl vent. How do I get that crap out of there?
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
Old 09-22-2004, 02:34 AM   #2
neonlarry
neonlarry's Avatar
Take the cowl off. Wiper arms, screws and bolts at the ends. If you are going to park under a tree suggest you put a screen in there before replacing cowl.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-22-2004, 02:38 AM   #3
1972C10
1972C10's Avatar
air hose the hell out of it thats the only way i found to get it all out of the cracks and crevices
1972C10 is offline   Reply With Quote
Old 09-22-2004, 02:47 AM   #4
shortymac83
hmm...
where are the screws and bolts, and can I get at all of them without taking body parts off? I've tried hosing them, air hosing them, pressure washing it, nothing works.
Old 09-22-2004, 04:04 AM   #5
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
yes you can get to all the screws if you just open your hood...and to get the bolts just open your doors...the trickiest part maybe getting your wipers off...sumtimes there a fight sum there not...
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 09-22-2004, 04:04 AM   #6
Gee_Emm
I stick a garden hose in there at full blast, let it run until you get a good stream of water running out of the bottom of the truck on BOTH sides. If it is really bad you might have to open the cowl vents and stick your hand in there and fish out the stuff. While you are at it take the hose and rinse out the wheel arches, just shove the hose up in there while it is on. Also make sure that the drain holes are clear, there are 2 on the front fenders and 2 in the doors.
Gee_Emm is offline   Reply With Quote
Old 09-22-2004, 08:47 AM   #7
71-longbed
Its Magically Delicious
71-longbed's Avatar
i tapes a series of hoses on the end of a shop vac and sucked all that junk out ... you've have much better air flow through your kick panel vents afterwards
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 09-22-2004, 09:04 AM   #8
Blue Beard
Blue Beard's Avatar
I believe LMC has a set of vent screens that will help keep these clean...
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 09-22-2004, 03:19 PM   #9
sactoC10
71 DELUX
sactoC10's Avatar
Am I wrong?
When I got my truck last year it had the EXACT same problem. PO left it parked under a pine tree, needles everywhere and I am still removing dried sap with GOO-OFF.
Anyway, I had to remove my cowl to get all that junk out. Will remove it again to do some painting in there. But as I remember this procedure, the doors also had to be opened and at least one bolt on each side removed to get the cowl totally free'd up.
No?
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50
2003 FORD Escape
1998 Honda VTR1000
sactoC10 is offline   Reply With Quote
Old 09-22-2004, 03:23 PM   #10
Alex Hayley
Also, use a shop vac to suck the crap out of the vents in the kick panels.
Alex Hayley is offline   Reply With Quote
Old 09-22-2004, 04:13 PM   #11
70c10
67-72 Addict!
70c10's Avatar
I believe it's only 4 bolts holding the cowl on. Be careful with your antenna.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-22-2004, 10:25 PM   #12
shortymac83
hmm...
what antenna? it was broken off flush with the nipple (I guess you'd call it) that connects it to the sheetmetal. I'll probably put on a late model antenna just so I have something to listen to (WLS BABY! lol). Thanks a lot guys, so the only bolts I need to remove can be accessed in the door jambs and under the hood?
Old 09-22-2004, 10:59 PM   #13
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
SOUNDS LIKE YOU NEED A OE DELETED ANTENNA COWL TO ME.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-22-2004, 11:14 PM   #14
Joe67
67 is sold
Just fill your antenna hole in like we did
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 09-22-2004, 11:56 PM   #15
shortymac83
hmm...
negatory! The truck is going to be completely restored to OE conditions, with the one exception of paint color (that dark blue on new GM cars with 84 H/O door panels, dash pad, tuck 'n roll seat, and painted headliner).
Old 09-23-2004, 01:08 AM   #16
Vince Putt
Hippy
I torn my 67 down for a ground up rebuild
I found all kinds of things that worked their way through the cowl down into the Heater Box and only real suggestion I got is vacum the thing out, pay close attention to where the stuff has fallen if your lucky the stuff hasn't clogged the cowl drain holes at the bottom of the firewall. if they get clogged you can have all kinds of problems with water laying and things starting to rust. there are also drain holes in the doors. alot of doors have rotted away because water settle in there because the drains were clogged.
Vince
Vince Putt is offline   Reply With Quote
Old 09-23-2004, 03:20 AM   #17
shortymac83
hmm...
My doors are pretty well gone, and I don't care much about the heater box because, for now, it's a summer truck and the heater core is leaking like a seive (just connected the 2 heater core attachments on the thermostat housing to each other).
Old 09-23-2004, 05:22 AM   #18
72 CustomCamper
huh ???
72 CustomCamper's Avatar
10 screws 2 bolts and 2 wiper arms...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 09-23-2004, 11:26 AM   #19
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Chuck
4 bolts, like 70c10 said.
Two in the door jambs and two pointing straight down under the rear edge of the hood.
