Need pics of cruise control
hey guys i do not own a 67-72 chevy truck factory manual can anyone who has one scan the pages of how to install cruise control into our trucks i have a 67
thanx Nick ![]() |
Collector of Projects
I just bought a 72 C/30 camper and it has cruise control... I will take some pics when I have a minuite... its on a 402 BBC ...
I would like to see your pics as well. Mainly good shots of where the servo unit mounts to the inner fender and shots of how the linkage hooks to the carb.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
its all about the +6 inches
the 72 should be an under dash unit, 68 - 71 were on the turn signal lever.
I don't have any pics of the stuff on this computer. |
TTT
Franko72
how rare are the original installs? My 72 is an under dash unit that says master cruise under the button.the unit is inner fender mounted with a cable
going on the carb bellcrank just below the throttle cable
![]() 1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach My Home Page Better to burn out than it is to rust Last edited by franko72; 09-23-2004 at 11:28 PM. |
Here are the pics I took today. They are from the 72 C/30 Delux camper that I bought. The cruise control is mounted on the driver side inner fender. It has a few wires that run into the cab for power from the fuse panel and tot he switch on the turn signal lever. There are two cables that drive the unit. One from the tranny to the box and one from the box to the speedo. There are also two vaccume lines. One is tapped into the brake booster line and the other goes to the diaphram next to the carb. I can send full size pics if needed...
lol no pics showed up my friend???
Nick ![]() |
That one is an 80's add on unit. My dad had one installed on his AMC Eagle
ya i thought for some reason it looked a little odd lol
#13 |
Thats a Dana aftermarket cruise mcmlxix.
Cruise activator switch was on signal arm from 68-70. 71 was underdash with cruise master written across the bottom...in 72 it was off to the side and had a light in the housing. the 71-72 type both mounted under dash. I've seen both style under dash cruises in 71's and 72's. Seems that 70 was the change over year to the underdash switch ...had people convince me it was both ways in 70... being lever or underdash.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
#14 |
![]() Join Date: Mar 2000
Robo I forgot I had posted pics on the board before and I just searched for the thread and found it. Here's the pics of mine that you wanted. Follow the link.http://67-72chevytrucks.com/vboard/s....php3?t=104846
Saskatoon, Saskatchewan Canada |
#15 |
hey thanx for the pics
