Old 09-22-2004, 03:42 AM   #1
85Silverado
85Silverado's Avatar
SM465 Shifter
Is there anyone who knows of a aftermarket shifter for this trans? Mines gotten pretty sloppy and am hoping to remedy this very soon. Any help would be greatly appreciated. Thanks in advance.
Paul D.
'78 C20 Scottsdale
350ci
3 speed with granny gear
14 bolt rearend
My trucks are "Car-Guy safe".......which pretty much means death trap in the hands of a normal civilian.
85Silverado is offline   Reply With Quote
Old 09-22-2004, 04:28 AM   #2
ZOOMY
465 shifter
Your local GM dealer can order a repair "kit" for the shift handle. It's basically the nylon part at the bottom. To get the handle out. push down on the collar at the bottom of the handle & rotate it about 1/8 turn CCW as looking at it from the top. Then lift the handle up. I always do this in neutral. Don't know if it'll come out in a gear.
ZOOMY is offline   Reply With Quote
Old 09-23-2004, 03:10 PM   #3
poff
Also check the roll pins that hold the retainer. If they are worn, new ones may help.
'70 K-20 San Diego, CA
poff is offline   Reply With Quote
Old 10-25-2004, 12:31 PM   #4
poff
FYI: the roll pins are 5/16" dia. and 3/4" long.
Old 10-25-2004, 08:40 PM   #5
82 Silverado 4X
Genuine Chevrolet
82 Silverado 4X's Avatar
I rebuilt the shifter that I installed in my 82 last year using a short section of Tygon Tubing compressed into where the nylon insert would go. Also check out the welds between to half-sphere and the shaft. My original shifter had cracked welds that made the sphere loose on the main shaft. If the welds are broken get a new shifter assembly because the sphere is made of some kind of casting that absorbs oils and makes it near impossible to reweld.
My original stock shifter would hit the dash in 1st and 3rd gears because of the slop.
My rebushed replacement feels like I installed a brand new unit.
George
82 Silverado LWB 4x4 350 SM465 NP208
77 Chevrolet Blazer Chalet 400 TH350 NP203
82 Silverado 4X is offline   Reply With Quote
