Wheel bearing
I think I have a rear wheel bearing going out on my 96 Suburban. Has anyone ever changed one? Do you have any advice? What does the bearing go for $ ? Also if you have had it done at a shop what did you pay? Thanks for any help you can give me.
1967 C-10 Use to be Riptide |
Not really that big of a deal since the complete assembly bolts in. Not sure what a new one costs.
95 K3500 SRW 5.7L Vortec 4L80e 4.10 G80 2001 GMC C3 6.0 AWD, Volant, 3/5 drop TBSS intake, HP tuners, pullies, 05 efans, 05 front brakes, etc. 2003 Tahoe Z71 Silverado front clip |
I'm curious about this as well...am I to understand the outer wheel bearing on a 5-lug 8.5" rear bolts on? I thought they were a press-in bearing. I have a mild roaring/rumbling developing, so i will need to replace the bearing or have it replaced.
1990 GMC Sierra SLE X-cab |
I finally got an avatar
I just did mine on a 9.5" rear and it was about $100 for both bearings and seals. Use a slide hammer to pull the old ones out and a big socket or something similar to drive the new ones in. took me about 2 hrs. I am pretty the 8.5 is the same procedure.
-72 C-10 short step (straight line only) 12.922/102.28 -69 C-20 on Propane (DD) -69 C-10 -56 Mack B-753LS (tow rig) -94 Chev K2500 Short Ex-Cab -89 Isuzu Trooper...Kinda -03 Kawasaki KFX-400 -05 Suzuki DRZ-400S |
| Bookmarks |
