Old 09-22-2004, 11:47 PM   #1
Ironhorse
Ironhorse's Avatar
71' Chevy Rad Support F/S
Removed a decent useable radiator support from a '71 2wd LWB. Straight, has both fender braces at the corners. Non A/C truck, support has not been chopped up. Some surface rust at the passenger lower area under the battery. (Usually is, isn't there ) Lower radiator supports missing but these are easy to rivet or weld back. Couple small (1/4") rust thru spots but not bad at all. POR 15 candidate and good to use. Local pick-up (or may deliver within reasonable distance) would be best as shipping this would be a bit pricey but will do so if someone wants to cover the cost. Can do pics on request for email address. $60 plus shipping if required.
Also have both the left, right, and center grille support braces I removed from the egg crate grille. $20 plus shipping, which will be easier than the support.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 09-23-2004, 11:30 PM   #2
Ironhorse
Ironhorse's Avatar
ttt
Wellington, Ks
Old 09-27-2004, 01:49 AM   #3
Ironhorse
Ironhorse's Avatar
ttt
Wellington, Ks
