09-23-2004, 12:30 AM | #1 |
Vaccum advance??
Well after beating my head againts a wall for two weeks I finally broke down and pulled the distributor retimed it and it fired right up. Guess I had a plug wire out of order?
Anyways I was shooting for 12* before but wound up with 10. As soon as I hook the advance up AT IDLE it jumps straigt up to 28*. I know its good to have it come in as soon as possible, but at idle seems a little to quick to me and could be why its not performing the way I think it should. Do I need a new canister or a new spring and weight set? I found the weight set in summit, but no canisters. Probably better off to do all of it right? I switched it to my ported hook up so it now has 12 at idle, but if you barley touch the throttle and give it vaccum it jumps to 28. Now on to fixing the rear end.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
09-23-2004, 01:19 AM | #2 |
You get what you pay for
Yes, you need a new canister. A Crane adjustable vacuum advance canister. Stock cans usually provide 20 to 25 degrees of advance. A lot of folks will tell you to hook it up to a ported source. This will lower the advance at idle but IMO, is the wrong way to go about it.
Read this article. http://www.73-87.com/7387garage/drivetrain/hei.htm
Mike 1985 Chevy C-10 |
09-23-2004, 07:13 AM | #3 | |
09-23-2004, 10:25 AM | #4 |
Good article, lot there I never thought about.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
