Garage Queen Material
steering problems...
since i've changed my spindles from the 2.5" western chassis ones, to the 3" djm ones, the steering is a lot different.
there seems to be a lot more play in the wheel and the truck will "glide" to the right side while driving. i didnt move the tie-rod ends or anything that would affect the steering. anyone know whats up with it? |
Under construction!
Did you have the front-end aligned after installing the new spindles?
2001 Silverado bagged on 22's. *Sold* |
#3 | |
#4 | |
It maybe a situation where the leverage of the 3" spindles is exagerating a problem that was already there, such as worn tie rod ends. That is what happens alot of times when people switch to bigger tires. The steering system is worn, but its not noticeable until you put on the bigger tires.
You get what you pay for
![]() Join Date: Dec 1999
Anytime you do any work at all on the front suspension, it's a must to realign the thing. What's the chance that the tierod mounting points on the spindle will be exactly in the same spot they were on the stock ones?
Mike 1985 Chevy C-10 |
#7 | |
Trucker.
www.73-87chevytrucks.com
Ditto! You are still changing components, so it needs to be realigned.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
It may need to be aligned, but that wouldn't cause him to have more play in the steering would it?
Stepsides RULE
So when i change my shocks in about a month, i need to take my truck to the allignment shop?
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
#11 | |
ROCKET POWER!
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild |
