![]() Join Date: Sep 2004
Lowering my 70
I'm planning on lowering my 70 chevy. Most of the kits I have seen are set up for coil spring rear end. I have a leaf spring rear end. What is the best couse of action in this situation? I would like to go 4" and 3" does tha sound pretty standard for a drop? Where is the best place to purchase the kit? Thanks in advance for the input
Watch out for your cornhole !
![]() Join Date: Jun 2003
Early Classic Enterprises sell parts to lower leaf spring rear trucks.
its all about the +6 inches
A spring flip kit would get you a little more than what you are looking for, so de-arched springs is probably what you'd need. Although, I'm not sure if you could get 4 inches that way.
Early Classic 4 inch drop leaf springs part #02-6372-4LF
![]() Go HERE for their webpage of them and type in the word "leaf" in the search box.
would lowering block be an option? 369.00 for 2 springs seems a bit salty. I don't mind spending the money if taht is what it takes, but I would like to know if blocks is a good alturnitive?
67-72 parts collector,…
![]() Join Date: Nov 2002
You would have to "flip" the rearend to use a lowering block. And,... if you flip the rearend, you would drop the back at least 6 inches. (Lowering block would not be required) Also a frame notch might be required. Look at ECE's stuff. Springs and shackles.
Fabricate till you "puke"
You can flip the axle.....then take the spring hangers off the frame, & drop them down to raise the truck back up a tick
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
