Old 09-23-2004, 04:11 PM   #1
87Silvy
87Silvy's Avatar
Lowering Rear
What would I need to lower the rear of my truck so that it sits level?
1987 Chevrolet Silverado
2005 Chevrolet Silverado
87Silvy is offline   Reply With Quote
Old 09-23-2004, 04:23 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
If you are at stock height, just get some rear shackles. It should drop about 2 inches.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 09-24-2004, 01:41 PM   #3
88Jimmy4x4
88Jimmy4x4's Avatar
http://www.73-87.com/7387garage/gara...suspension.htm
http://67-72chevytrucks.com/vboard/s...threadid=84340
Just remember with shackles you will have to notch the underside bed support for clearance. No biggie, but you will need a sawzall or something.
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 09-24-2004, 03:08 PM   #4
87Silvy
87Silvy's Avatar
After reading the thread that Tim had posted, I think I want to go with the 2/4 drop. Could I use the 2" drop springs for the front and the 4" shackle/hanger kit for the rear? Do I have to notch the rear for the 4" drop?
Old 09-24-2004, 03:52 PM   #5
cochino12
It followed me home?
cochino12's Avatar
shouldnt have to.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 09-24-2004, 05:35 PM   #6
mckpaul
mckpaul's Avatar
I haven't done mine yet, but looking at it, just above the shackles, there's less than an inch clearence between the top of the shackle and a cross member bed support. I read somewhere that the crossmember had to be notched to allow for longer shackles. Doesn't look like a major thing, not really a suspension or 'support' crossmember, just looks like reinforcement for bed floor strength.
Paul
1984 Chevy C-10
*LWB/305*
mckpaul is offline   Reply With Quote
Old 09-24-2004, 06:44 PM   #7
88Jimmy4x4
88Jimmy4x4's Avatar
Yup, its no biggie if you have the tools.
1991 GMC Jimmy 4x4
Old 09-24-2004, 09:16 PM   #8
cliffsta
Stepsides RULE
cliffsta's Avatar
i think / thought if you used hangers all you had to do was, well, hang it. Are hangers different than shackles? What about shims? How do shims work?
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 09-24-2004, 09:44 PM   #9
88Jimmy4x4
88Jimmy4x4's Avatar
Spring hangers are more work IMO, its not easy getting those old rivots out. Shackles are between the spring hanger and the spring eye at the rear. Shims are just that....shims, kinda like a wedge if you will that goes under the spring pack to adjust the pinion angle upwards or downwards.
1991 GMC Jimmy 4x4
Old 09-24-2004, 11:02 PM   #10
cliffsta
Stepsides RULE
cliffsta's Avatar
so outta the 3 listed above, which is best for ride quality using original leaf springs?
if i were to invest in new springs, they would be drop n e ways
Old 09-25-2004, 02:36 AM   #11
swervin ervin
You get what you pay for
swervin ervin's Avatar
You don't want to use the front hangers by themselves. It throws the pinion angle all out of wack.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
