Old 09-23-2004, 10:40 PM   #1
darksaga
darksaga's Avatar
redid my gauge setup
well while debubaing my electrical system I rewired my gauges, used a ATX extention cable to use as a conecter
worked out pretty good and now it will be easier to pull when I need to :-) and I won't have to remember what wire goes where, and the conecter has plenty of room for expansion
I also doubled out on the power and grounds to help power handleing
1968 gmc 3/4 4x4 longbed. built 469 700r4 (needs a th400 REAL SOON!), 14bolt ff rear 73 3/4 dana 44
1970 chevelle all wheel disc, tubular rear control arms tall spindle swap up front matching #'s 350 work in Progress
darksaga is offline   Reply With Quote
Old 09-23-2004, 10:45 PM   #2
john
member #16
john's Avatar
Very interesting,looks good. Do the fuel guage and speedo have lights? John
john is offline   Reply With Quote
Old 09-23-2004, 10:54 PM   #3
darksaga
darksaga's Avatar
yes they use the original harness I plan on swaping in a matching spedo and tach and getting matching fuel gauge eventualy
Old 09-23-2004, 11:20 PM   #4
Inspector722
Fixing my 67, & loving it
Inspector722's Avatar
For $6, you can get the white faces for you speedo and fuel guage from the company on ebay. And that inculdes shipping.
Email address- inspector722@aol.com
Zip Code- 77611
Shipping- DHL & USPS
Working on: 67, large back glass, 307 V8, 200 4R, 3.73 rearend, Short Stepside Bed
Inspector722 is offline   Reply With Quote
Old 09-24-2004, 12:00 AM   #5
formerfordguy
72 GMC SWB
formerfordguy's Avatar
looks cool .will be nice when you pull it just unplug it . i like that ....
formerfordguy is offline   Reply With Quote
Old 09-24-2004, 12:25 AM   #6
darksaga
darksaga's Avatar
I may just do that, but the gas gauge is broken and the spedo bounces llike crazy even after I oiled the cable
Old 09-24-2004, 12:30 AM   #7
68 Stepside
huh?
68 Stepside's Avatar
an ATX cable....never thought of that!! Thanks for the idea
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 09-24-2004, 05:32 AM   #8
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
What's an atx cable? Also, could you use the sockets from the sidemarkers to fit the dash light outlets? You could get rid of that darned printed circuit board if it works.
Looks good.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 09-24-2004, 06:12 AM   #9
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
I knew someone else would think of this. I haven't had to rewire my dash but I did install a tach in the center hole of the dash. I used a molex connector for it.
BTW ATX plug is the power wire for a PC that has the atx form factor. A molex conector is the 4 prong plug that plugs into hard drives and cdrom drives.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
