Old 09-24-2004, 12:44 AM   #1
Russell
Professional Grade
Russell's Avatar
Exhaust Hangers
Hey guys!
I'm putting my dual exhaust on this weekend, but I need some help -- I've gotta figure out what to use to make hangers, and where I need to put them...
It'll be a 2.25" dual exhaust setup with an X-pipe, and Aerochambers, all running up to the factory manifolds for now.
I'd prefer to build something if possible so I don't have to go and buy a bunch of hangers... The mufflers are gonna be costly enough as it is, lol
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 09-24-2004, 01:09 AM   #2
Russell
Professional Grade
Russell's Avatar
Here are a couple pictures of what I've got right now, I decided I needed to move the axle pipe to get as much clearance between it and the blazer tank as I could, but is that too close to my shock? You can also see that the hangers that came with the pipes are too flimsy, thats after going out for a single trip. So I used some wire to help hold the pipe solid, but I do wanna make a better hanger...
Second picture is just a picture showing off the lovely wheel well of my truck with the pipe coming out a bit crooked :p The filler neck is for the Blazer tank, I gotta figure out what I am gonna do with it...
Old 09-24-2004, 05:53 AM   #3
PHOENIX
You should be able to buy hangers from a local auto parts store.
The quality is good and price is ok.
Galvanized with rubber isolators and different holes punched for adjusting.
They look similar to these:
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
