Old 09-24-2004, 03:35 PM   #1
bill71
Worn door hinges.... what to do?
I have a 92 hit in the drivers door. I need to replace the door, and the hinges sag, too. Does anyone know if somebody makes bolt on replacement hinges?
bill71 is offline   Reply With Quote
Old 09-24-2004, 04:45 PM   #2
Stevetra
I dont know about a bolt on replacement, but for $6.00 at advanced auto parts you can get a new hindge pin and bushings.
I had the same trouble, and it caused my wife to rip the whole freekin door panel off to shut the door.....sigh...
I replaced the bushings and pins and the doors closes like new money.
Now just gotta find a grey door panel....
Stevetra is offline   Reply With Quote
Old 09-25-2004, 04:54 AM   #3
Bowed
Yes there is a bolt on replacemant that body shops use but I imagine they might not be that easy to install with the way the door framing is designed . the first repair to try is the one mentioned above and replace the pin and bushing . If that is not enough to cure the problem the next fix is to bend the hinge and even though there is a special tool for that task , I have done it sucessfuly with ordinary tools , they bend easier than the old ones . I have also tweeked them by jacking against the bottom of the door to bend the hinges slightly but be careful here and do it just a little at a time until you get it to shut properly . If you bend it too far up you wind up with a problem that is worse than the one you had .
Bowed is offline   Reply With Quote
Old 09-25-2004, 08:37 AM   #4
99-2door
99-2door's Avatar
GM replacement hinges bolt on. They are pretty pricey though.
95 K3500 SRW 5.7L Vortec 4L80e 4.10 G80
2001 GMC C3 6.0 AWD, Volant, 3/5 drop TBSS intake, HP tuners, pullies, 05 efans, 05 front brakes, etc.
2003 Tahoe Z71 Silverado front clip
99-2door is offline   Reply With Quote
Old 09-25-2004, 10:43 PM   #5
RemoteControl
I am not sure what manual you have been reading but every chevy hinge from about '88 on were welded on and are a pain to replace. Hinge pin and bushings are the only other way the fix a sag, unless the hinge halves have been rubbing together for a long time without a bushiing in between them, then you will have to replace the hinge. I have worked at a GM dealer 15 years. You will need another set of hands to do a bushing/pin R&R unless you have a hydraulic jack with an beam attachment. L8R
PEOPLE THAT THINK THEY KNOW EVERYTHING ARE PARTICULARLY ANNOYING TO THOSE OF US THAT DO !!
Dropped 93 Chevy Std Cab, 454 SS conversion, 20 in Centerlines, Wrap Around Ground Effects
RemoteControl is offline   Reply With Quote
