Old 09-24-2004, 05:23 PM   #1
Brently
How can i find out what an intake is off of? I have the numbers off of it! help!
i bought a 4 barrel 327 intake and can't figure out what it is off of - the seller said it came off of a 63 corvette - the numbers off of the intake directly behind the carb are 3872783 - can anyone help or do you know where i can get help? every 4 barrel rochester quadrajet i have does not fit properly because the 4 holes that bolts it down don't match up - thanks
Brently is offline   Reply With Quote
Old 09-24-2004, 05:28 PM   #2
rage'nrat638
rage'nrat638's Avatar
http://www.thedirtforum.com/castings.htm
just do a search for g.m. casting numbers on the web.....
9157 sites come up.....
rage'nrat638 is offline   Reply With Quote
Old 09-24-2004, 05:54 PM   #3
cwilli84
1FINE69
cwilli84's Avatar
Mortech's website is also a reasonably good source too
Had a 69 swb fleetside 350zz3 w 400turbo trans oak lined bed with rhino coated sides red exterior. SOLD
cwilli84 is offline   Reply With Quote
Old 09-24-2004, 06:00 PM   #4
69ChevyLB
Active Member
69ChevyLB's Avatar
intake
My book shows it's off a 66/67 283/327 220, 275, 300 horsepower with Holley carb.
69ChevyLB is offline   Reply With Quote
Old 09-24-2004, 06:27 PM   #5
Brently
intake numbers
i guess a bigger question to ask is what carb am i looking for to fit this intake? like to keep as original as possible - thanks, Brent
Old 09-24-2004, 07:26 PM   #6
69ChevyLB
Active Member
69ChevyLB's Avatar
carb
Probably a 4150 600 cfm Holley. That manifold probably takes a square bore carb and not a spread bore like a QJet. Check Holley,s website. The have Calssic carbs listed.
