Old 09-24-2004, 06:19 PM   #1
Curbstone Mech
Active Member
Changing steering column parts
I'm running with a mid seventies van tilt( shifter on the cloumn) and I want to put in a floor shifter, and replace the cup with a smooth one, or should I say one that only has the tilt lever and turn signal. Does anyone know what type of column I rob the part from?
Thanks alot.
68 short fleet
383 stroker, 700r4 373:1 posi
72 GMC 3/4 ton- weekly driver
700r4 351;1 posi
Curbstone Mech is offline   Reply With Quote
Old 09-24-2004, 06:39 PM   #2
71swb4x4
71swb4x4's Avatar
You are pretty much going to have to get it from an original truck tilt that was for a 4-speed, and if that is the case it will cost some coin.
It would be far cheaper to cut the shifter mount off of your existing cup and fill it. One person ont he board did it (don't remember who) and it turned out very nice.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-24-2004, 06:44 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
I did it to mine and although the body guy hasn't got around to painting the column yet, should be an invisible alteration. http://yukon.b0xen.us/albums/vantilt/
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-24-2004, 07:26 PM   #4
Deuce
Deuce's Avatar
That should look good. I have a original tilt with a worn pivot pin that I'm going to have to try this to.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 09-24-2004, 10:43 PM   #5
john
member #16
john's Avatar
Yukon all I get are two pages with #'s John
john is offline   Reply With Quote
Old 09-28-2004, 10:24 AM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
John, maybe try again, when I hit the link the album comes up. If you can't get them to come up, pm me your e-mail address and I will send you the pics.
Old 09-28-2004, 10:27 AM   #7
Curbstone Mech
Active Member
Thanks. I'll give it a try!
68 short fleet
700r4 351;1 posi
