Member since 2000
Lots of cutting and lots of welding..................hope to have the windshield complete and maybe the right side floor. What about you guys?
huh ???
Gonna try to get my 66 396 installed. Finally sold the 402...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
1969 C/10 Longbed undergoing rebuild. Old Chevy's Never Die, They Just Rust Around The Edges |
I consider anything I get done a success. Considering my crew, 2yr old and 3 1/2 yr old. They are great though.
Still drivin' a Rat Rod
I'm hoping to get the interior all painted,stereo installed,seat recovered,lights working,and muffler hangers put on the 71,and the brakes on the 49 if time/money allows.
WHew! That looks like a lot of work ![]()
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
User #12137
![]() Join Date: Apr 2004
well i am just going to put gas in mine and get out there and ride around in it and enjoy the ride !!!!!
I am planning on working on my New company truck Installing the bedliner/Side and tool boxes off the old one and maybe build a ladder rack Depends on how lazy i get.
72 GMC SWB
take mine to go see my boys play peewee football....
I hope to finish my power locks/keyless entry/alarm today. That along with putting in a few new pieces along the way.
Then I need to get my plates drawn up in AutoCAD to get cut out for my firewall covering the factory A/C holes. May do a little to get the new A/C more in the direction of installed. Other projects I have outstanding... Change tranny pan and gasket, change oil pan gasket, all the A/C stuff, another new windshield/gasket/trim install, and some other little bits I am sure I am forgetting. This is after I have already "finished" my truck. ![]()
Orange '71 GMC |
I just finished installing new window weather-stripping in my 70 Chevy Custom Camper 20, and will be doing the door seals this weekend. Winter will be here before you know it.
Active Member
![]() Join Date: Feb 2000
I'm planning on putting on an accel blue air filter element to match the blue ignition wires, put on a chrome glove box door, polish the wheels.
68 short fleet 383 stroker, 700r4 373:1 posi 72 GMC 3/4 ton- weekly driver 700r4 351;1 posi |
My weekend goals are to replace the R. side inner & outer rocker panels, & cab support. I'm 92.3% done.
The rest of the weekend consists of going to the Super Chevy Show.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
#13 |
my goal is to start on the custom cab mounts, need to remove the curent
frame mounts and build newones
Mike K Friend of Bill W |
#14 |
I may try to sand out some rust that has puckers my lower drivers side finders paint and smooth things out and prime the area
72 long fleet (WIP) ![]() 00 Astro every day ![]() |
#15 |
A classic GM kinda guy
Did fresh plugs, wires, set timing, oil change, lube, and total visual inspection Friday.
Saturday, take her out on a long drive (200 to 300 miles total). Sunday, wash her up and give her a good coat of wax.
Old school rap music: a dual exhausted GM 6 with no mufflers. "If you can find a better vehicle, buy it" Lee Iacocca, Chrysler commercials of the '80s. "I did. They are called Classic GM pickups !!!" ![]() ![]() |
#16 |
This weekend I'll be planing what to do next weekend.
#17 |
I'm gonna go outside and wash it up in a few minutes, then I plan on putting as many miles on it as possible this weekend. Have put on about 130 miles over the past couple evenings. Gotta take advantage of the nice weather while we have it, the truck goes away on October 15 and won't be coming back out till May
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
#18 |
i'm just concentrating on parking it where in case trees fall during the weekly hurricane that it don't get crushed
#19 |
Got Light Emitting Diode?
i will be cleaning up the donor brake parts for my truck(spindles, calipers, and dust shield) and painting them. maybe buy the tierod ends and ball joints.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
#20 |
huh ???
Other things I have to do is pick up the new truck I just bought, an 86 K10 long bed, and help my neighbor install new gears in his truck...
Chuck
#21 |
![]() Join Date: Mar 2004
humm lets see. drive 2.5 hrs to pick up a 68 with a freshly referbished cab and frame for $500. finish grinding the edges on my 71 frame. build up and grind smooth the welds on the 71 a arms oh and find some time to relax and pass out untill monday.
cheers=) ondrew |
#22 |
72 Cheyenne
Well if I have the energy tomorrow I'm going to remove my front wheel wells. I have a set of new powder coated to go in and a new battery tray.
#23 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Hope to get the bed bolted back together for the 69 and help pont with some welding.... After that it look's like yard work.... Ohh ya I should wash and wax the blazer..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#24 |
Formerly yellow72custom
Next weekend when i see my truck next i plan to start it up and drive it around the yard...sadly its the only use it sees anymore
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
#25 |
Weekend not going as planned,can I relist my goals
