Old 09-25-2004, 07:58 AM   #1
Poe
Int Door Panels and Seats
Does anyone know if the 72-style door panels will line up with 67 door holes and handles? Any problems with using 72s on the 67?
Also, if someone has installed bucket seats (or similar) in their 67-72, please let me know what they were from. I have heard van seats go well, but I would like to hear from someone who has actually done it, see what fits well, and maybe get some pics.
Thanks Guys,
Poe
67 Chevy Owner
Trying to restore it or fix it up a bit
Poe is offline   Reply With Quote
Old 09-25-2004, 12:16 PM   #2
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
They will line up but the 72 style door panel requires a longer window crank shaft. Also, the '72 used push in clips at the bottom of the door panel and had round holes in door while the 67-71 had screws at the bottom of the door panel and the door had a threaded nut welded in a square hole.
Would need to make modifications for it to work.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 09-27-2004, 02:22 AM   #3
Kas68c10
Kas68c10's Avatar
I have done it, its works fine, I got the fasteners from a big rack of fasteners they had at an auto discount store. The vinyl 72 are much nicer imo. It was harder changing the window and door cranks, but not too bad.
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!!
Kas68c10 is offline   Reply With Quote
