Old 09-26-2004, 03:03 AM   #1
64fleetside
WTB:250 power steering pump bracket
Need a power steering pump mount bracket, I have just gotten one but it seems to be for a newer integrated head, it is close but no cigar. Any out there for the original 250 in a 70? Thanks, Brian
64fleetside is offline   Reply With Quote
Old 09-26-2004, 03:05 AM   #2
Piper71c10
Unending Project
Piper71c10's Avatar
Any Pics of an installed unit as well? Thinkin about upgrading my '66 and I'd like to know where the alternator goes.
Piper
Piper71c10 is offline   Reply With Quote
Old 09-30-2004, 10:39 AM   #3
64fleetside
I think the alt stays where it is, & the p/s pump bracket has the slot for alt adjustment. Still hunting a bracket setup, I have found the pulleys & a box. Brian
Old 09-30-2004, 11:01 AM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
here's a pic, not for sale
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 09-30-2004, 04:11 PM   #5
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Hmmmmm. CPNE's setup uses a combination of later model (wider spacing on the bottom crank pulley grooves) and other pump setup, which is running off one belt. The original had two belts and close together.
Here are three setups that I have put together that fit our closer/original crank pulley. You may still have to run one belt or two depending on which pulley groove you use. These were checked on a 70 250 pu engine.
http://67-72chevytrucks.com/vboard/s...hreadid=108987
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 09-30-2004, 06:18 PM   #6
64fleetside
Pickmup, you still have those setups? I got some double groove pulleys Monday. Need the bracketry, this thing is a monster to steer, either I'm getting old or the 35 y/o ball joints are stiff, maybe its the radials. Brian
Old 10-01-2004, 03:28 AM   #7
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Yup! Take your pick.
Phone: 360-956-7170
Old 10-01-2004, 08:11 AM   #8
64fleetside
I'll take the one on the left in photo, it has the same style bolt on pulley as the double pulley I picked up. How do you need paid? Brian
Old 10-01-2004, 02:38 PM   #9
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
PayPal, Visa/MC, MO---Trade for 3/4T 4X4 front hupcaps
Frank's PICKMUPS
1516 46th Ave. N.E.
Olympia, WA 98506
(360) 956-7170
Phone: 360-956-7170
Old 10-01-2004, 08:52 PM   #10
64fleetside
Frank, you have mail, thanks, Brian
