Dual Exhaust ?'s
would adding 2" dual exhaust with glqass packs hurt the performance on a basicly stock engine? any good ideass on how to create some power and noise with the exhaust?
-Chops- |
its all about the +6 inches
That should increase performance. it would be even better if you add headers too.
Speed Limit = Floorboard
Actually stock hurts performance. 2 inch and glasspacks will be lots better than stock. What kind of motor is it? your sig says 67 truck so I'm guessing its a 327 at the most. I'd go with 2 1/4 with glasspacks. Headers would be a great add on too. Lots of flow. Most of the stock exhaust is like trying to breath through a coffee stir stick. Robs power and mileage.
1971 C20 350, 4-speed - Sold. 1985 K10 350, Built 700r4, Edel 1406, Performer intake, MSD Ign, Hooker Comps, Silverstars, Piaa drivers, LED tails, Toyo A/T 31's, Eaton Posi, the project. "Build for torque, horsepower will follow" |
yeah, what they said.
72 GMC sierra 3/4 ton 402 bb ![]() 68 GMC 3/4 ton ![]() 2010 camaro rs: daily driver |
excellent. thanks alot for the information. some one elsewhere said tht the dual exhaust would ruin my performance and i thought otherwise and you all helped answer that. and its actually a later 305 in my 67.
-Chops- |
I guess you could argue that if you went really big on your exhaust it could lower the torque with a stock engine... A could set of duals is all you really need on that 305.
Left Foot Functioning
Good point, Dean.
For the 305, I'd probably stay with 2" pipes to keep the flow up. Larger could detract from your low-end. Glasspack noise output is a combination of diameter and length, so with a 2" diameter, you'll probably stay out of trouble with the sound police with anything 24" or longer. If you have ambitions of a larger motor, especially bigger than 350, might want to go with the 2.25" pipes. SSOW ![]()
69 C10 (#1 son's ride) 72 C20 (Dad's farm truck) 82 K30 (Ex - brush pumper project) |
Yeah with a 305 they are right about keeping the smaller pipe for torque, you could also invest in an h-pipe or x-pipe if you wanted that also helps torque by balancing out the tubes. Depends on what you want for sound, like they said bigger pipe rumbles more. Dean has a point about that you could argue that big exhaust will lower torque but stock is pathetic period.... its designed to be cheap, not powerful.
you have got to have a double hump trans crossmember to get the clearence
under the truck..... check my store.... ![]() http://cgi.msn.ebay.com/ebaymotors/w...e=STRK:MESE:IT http://stores.ebay.com/RAGENRAT638S-...RUCKPARTS-MORE |
#10 | |
Insert funny comment.
![]() Join Date: Dec 1999
------------ - Mark -My Build Thread... -68 C10, LT1 - Undergoing Frame off resto -86 IROC-Z T72 turbo 355, M6 -70 Camaro http://www.iroc-ss.com |
