09-28-2004, 09:11 AM | #1 |
67 is sold
Running a parking brake?
How many of you guys who have restored a chassis are running a parking brake setup?
I'm rebuilding my chassis and have been thinking about this. Is it really necesasry? Thanks. |
09-28-2004, 11:49 PM | #2 |
I am assuming that you are going to have an automatic? I am, and plan on eliminating the e-brake. Mostly because I am going with disks in the rear. I have been thinking about puting an e-brake setup on my output of the t-case....
09-29-2004, 03:22 AM | #3 |
IMO if I was going auto I would get rid of it, with a manual I'd keep it.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
09-29-2004, 07:35 AM | #4 |
67 is sold
Yep - I'm planning on going auto. Thanks
09-29-2004, 09:34 AM | #5 |
Anybody ever have an auto that slipped out of park(worn pawl), it ain't fun when you're putting a boat in the water. Put the E Brake back on.
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
09-29-2004, 01:15 PM | #6 | |
67 is sold
The GMC will do my dirty work |
09-29-2004, 05:25 PM | #7 |
Seņor Member
You should check your state's regs before removing them. Many (most?) states require them to be on the truck and working as designed.
09-29-2004, 06:44 PM | #8 |
The LuvShack Garage
NOT TO HIJACK, BUT I AM LOOKING FOR A COMPLETE BLAZER SET-UP.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
10-01-2004, 06:53 PM | #9 |
Regular guy
Here in Texas we are required to have an e-brake to pass inspection.
The disc brake kit I purchased had the parking brakes built into the caliper but I just didn't like the way it was going to look. Also with the air suspension i'm running the two e-brake cables were just getting in the way. I went with this simple pinion mounted brake instead.
'Frank' 77 Silverado 18 & 20 American CL205s Edelbrock MPFI, 700r4, Baer Brakes 9" F@rd rear, Vintage air, Bags etc etc.. |
10-01-2004, 07:50 PM | #10 |
Watch out for your cornhole !
Take a look at a parking pawl in an auto transmission before you do away with your park brake. They're not real burly, and a heavy truck on a steep hill is a lot of stress on it. I think if you see it, you'd agree that a brake is needed.
All it would take is a pawl failure, a misadjusted linkage or a bit of inattentiveness to allow the truck to roll and possibly kill someone. Even so, I have seen vehicles slip the pawl. Click..click...click as the car lurched down a hill.
10-02-2004, 07:45 AM | #11 |
67 is sold
Good opinions, thanks guys.
7T7 - I'm interested in info on that pinion setup you have. That is the first time I've seen that. |
10-02-2004, 09:24 AM | #12 |
Regular guy
Here ya go Joe......
http://www.tsmmfg.com/Pinion_Mounted_Parking_Brakes.htm
10-02-2004, 09:51 AM | #13 |
67 is sold
Thanks. I'll give them a call
10-02-2004, 10:34 AM | #14 |
Here in Ohio, it is required to pass the random "safety check".
The pinion mounted units are great. Many years ago they used a drum set-up mounted to the transfer case on Jeeps. This higher mount is probably better suited to a 4X4 (to keep it away from damage) but it depends upon the driveshaft to stop the wheels. The pinion mounted unit doesn't have that draw-back. |
