09-28-2004, 01:00 PM | #1 |
How Low Can i Go with just springs
Just bought a project truck with brand new stock height spindles and im wondering how low can i go without having to change to drop spindles, and im looking to keep decent driveability and ride. thanks for your help
sean |
09-28-2004, 01:03 PM | #2 |
67 is sold
2" front drop springs may be it. I hear there are issues when you go with a 3" drop front spring alone.
Another point I've read here is that if you just go with a 2" front drop spring alone, you may not see much a difference if you started with old/worn front springs to start with. Personally, I'd do it right and go with a spindle/spring combo |
10-08-2004, 06:21 AM | #3 | |
Custom Truck, here I come
Sorry about the stupid question, but need to know. Thanks. |
10-08-2004, 07:40 AM | #4 |
Watch out for your cornhole !
I've dropped them plenty of times with 3 inch front springs.
Only problem is the stupid grin on my face because I did it so cheap. Yes, they will align fine lowered 3 with springs. As long as nothing is bent, you won't have any issues.
10-08-2004, 08:16 AM | #5 |
one set closer
so what about 4 inch spring will there be any problem with them.
10-08-2004, 05:39 PM | #6 |
67 is sold
I haven't even seen 4" front drop springs??
CPP makes a 3" frt drop spring |
10-08-2004, 10:26 PM | #7 |
one set closer
i bought a set from a board member last month.
