Old 09-28-2004, 04:45 PM   #1
6600DURAMAX
6600DURAMAX's Avatar
12 bolt disc brake conversion????
I am in the process of dropping in a posi and 3.73 thanks to some great members here but in the process was going to rebuild the drum brakes. But...... I was wondering if there was a cheap way to convert the 12 bolt to disc. I have done this on 14 bolt rear ends for fairly cheap using stock calipers and homemade brackets (work great too).
does anyone know where I can buy brackets and use 1/2 ton front rotors and calipers. seems fairly easy??
thanks guys
Also have to get a new brake booster and master cylinder, so I guess I would need one for four wheel discs (Used the stock one on the 14 bolt rear, seemed to work??)
1972 K5 Build - plans - LS3-6L80e-One Tons.....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 09-28-2004, 05:00 PM   #2
john
member #16
john's Avatar
Here is one using Seville parts that can be found in wrecking yard. John
http://www.classicperform.com/tech_a...kes-trucks.htm
Read this post.
http://207.44.196.117/vboard/showthread.php3?t=121249
john is offline   Reply With Quote
Old 09-28-2004, 06:25 PM   #3
6600DURAMAX
thanks john I will check it out
