Old 09-28-2004, 11:50 PM   #1
Destructo
Where to get T-Case seals
I have a seal or gasket go out somewhere between my t-case and transmission, leaks pretty bad while the engine is running, I gotta fix it quickly because I need the truck for drive next weekend for a 4x4 event which it will be towing the samurai down.
I don't know if Advance auto carries these things or not, or will I have to get them from a specialty drivetrain shop?
My front output seal and rear slipyoke seal were leaking some, so i'm going to fix those since I will have to pull the t-case anyway.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 09-29-2004, 01:15 AM   #2
donkey69
JB-80 "Twice as Good"
donkey69's Avatar
I had a 77 that leaked bad there-after tearing it down and chasing around town looking for those seals--finally ended up buying a roll of gasket material and made my own-used what was left of the old one for a template. Kinda tricky to get the old one off in less that a million pieces,but used a pencil to trace and a sharp razor blade to cut-worked good. Not much help to you?-but maybe a "plan B"!
HEY NOW!
donkey69 is offline   Reply With Quote
Old 09-29-2004, 01:17 AM   #3
poff
There are two different gaskets, one for each end of the adapter. There is also a seal in one end of the adapter, although I think some of the later trucks had two but I think the seal are the same at both ends. If you can't find them local you can get them form Border Parts in Spring Valley, CA: 619-461-0075.
'70 K-20 San Diego, CA
poff is offline   Reply With Quote
Old 09-29-2004, 04:32 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
NAPA has the seals.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 09-29-2004, 07:20 AM   #5
Phuloi68
I have gotten gaskets for transfer cases from a place in Ca.
Stick Only
9900 Glenoaks Blvd., No 2
Sun Valley ca 91352
For the seals, go to a bearing supply place and you will get them cheaper then a auto parts store. same for bearings.
Phuloi68
Indy survivor
Norwood survivor
Big Sandy survivor
for those who fight for it...
F R E E D O M
has a price the protected
will never know.
Phuloi68 is offline   Reply With Quote
Old 09-29-2004, 07:47 AM   #6
HeavyK20
HeavyK20's Avatar
http://www.drivetrain.com/ also has the parts you need.
Eric
1969 K20, 465/205 package
HeavyK20 is offline   Reply With Quote
Old 09-29-2004, 10:31 AM   #7
Destructo
I see advance auto carries the seals, but couldn't find the gaskets for the adapter.
Would just using some silicone sealant work? I know on my samurai all they use is sealant, no gasket of any kind.
I have gasket material laying around here somewhere, and a good trick to use is to place it over the item that needs the gasket and go around lightly tapping the edges with a hammer so that it leaves an indention of the surface and if the edge is sharp it will just about cut it for you.
Old 09-29-2004, 03:09 PM   #8
Destructo
Seals weren't bad, my adapter and transmission were coming apart, bolts were loose. So I pulled the bolts out, cleaned them and the holes and applied a generous amount of loc-tite and reinstalled them.
