Anybody here bagged a blazer?
I guess with my project(71 2wd blazer), I am going to start with the chassis...
which includes bags ![]() I was wondering if I have to do a C-Notch? If so...how do I make it so that the back seats still fit and what-not... any help would be great...maybe even a few pics ![]() thanks guys Lenny
Always looking for a 2wd blazer |
Member since 2000
contact brad2 , he's got a sweet 2wd in the works.
belly dragger
Yes you have to notch it if you want it to sit low, but I've built my notch and tub so it will fit under my back seat
67-72 parts collector,…
![]() Join Date: Nov 2002
grnddwn,... do you have any frame shots of your blazer? Front and rear. Cool ride,.... thanks. Lolife99.
Yeah, I would like to see a picture, if you can...
so, I can see what it looks like. how much head room do you lose with the seats? I figured you would have to cut the bed floor, and make it a little higher to cover the notch
Too Many Clubs Club
This Blazer isn't even C-notched in the rear and it sits nice and low.
How I installed my air bags... |
So, if it is not notched...then how did you get it so low?
From what I understood, you had to notch so that it wouldn't rub when you let all the air out.... I am just trying to figure out the best way to lower it... I know I want bags...because from what I know that is the ride quality is the best....
Too Many Clubs Club
It's not my Blazer, simply one I saw at Super Chevy. I snuck a peek under it to look at the bag set-up, and noticed it wasn't notched. I was also surprised that it sat so low without a notch.
Happy to be here
![]() Join Date: Mar 2000
I'm not sure what your concerns are about C-notching your ride. If done properly it won't effect the integrity of the frame. If it's done well, it might even make the frame stiffer.
My Blazer is an 82 so the frame is different from yours in the rear. Regardless I wanted to show you how it's notched. The notch allows the rear end to go within 1" of the floor pan. It's as low as you can go "without" cutting the floor pan. You can step-notch the rear and cut the floor too. If your concerned with still using the rear seat, just keep the step-notch small..... |
Happy to be here
With a small notch it won't go as low as some, but it still gets pretty low. The notch will make a huge difference in how low you can go and still drive....
![]() Join Date: Jun 2002
Trife, I just found a new website called webrodder.com that has some great tech articles. One is an Airride suspension swap on a c10 that should help with your blazer.
You have to join to get in but the tech articles are worth the trouble. Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
thanks a bunch...
I am trying to break all my projects down...and frame, and suspension are first...so, I just want to know what I am doing, before I get started.... gonna start taking everything off the frame in the next week or so...then the frame work is happening... thanks for all the help
#13 |
Too Many Clubs Club
Here's a pic of the axle/frame area on the Blazer I posted before. Notice how low the truck sits even without a notch.
#14 |
My blazer has about that much room also,... and mine bounces off the snubbers on most hard dips in the road. I really don't want to notch it, either. I have ECE's shock reloctors, shocks, adjustable panhard bar, and 6" drop springs. Does that blazer have bags or coils? Hard to tell in the pic.
#15 |
Yeah, that definitely looks good...
I really didnt want to notch, if I didn't have to, and I am told not to get that bolt in kit <shrug> I don't see why not, but oh well
#16 |
Too Many Clubs Club
The Blazer in the pic is bagged. Sorry the pic isn't better, but it was hard to get under it since it was so low.
#17 |
Questionable
Classic Chevy C-10 Upgrades - Part 1
Installing new disc brakes, dropped spindles and air suspension in the front of the 1963-72 Chevy C-10 Classic Chevy C-10 Upgrades - Part 2 Rear air suspension and plumbing suggestions for the 1960-72 GM trucks Six Pack to GO - Part 5 Rebuilding the front suspension for the 6-pack and all other 1963-72 GM trucks Some other articles: http://webrodder.com/index.php?searc...Stories&CID=11 http://webrodder.com/article.php?AID=42&SID=60
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#18 |
Got L.E.D.s
I did CCPs bolt in notch and it was very simple. I personnelly wouldn't lower with out a notch. But I had mine bagged in the rear prior to the notch. I didn't like it. I wanted to drive with it at the height that it sat when the rear axle housing was sitting against the frame. But thats the beauty of these trailing arm trucks, so easy to throw the coils and bolt bags in and see how you like it. Then you can always notch later. But don't screw up like I did and get firestone bags they don't compress as low and lift as high as Slam Specialties or airlift bags.
Bagged 1972 2wd Blazer http://www.earlyclassic.com/home.aspx |
#19 |
We used the bolt-in notch (99.00) from CPP on my sons 71 and it was very easy. Quality and fit was great. I guess if you were worried about it weld it in after. Now we did have the bed off so that did make access much easier but I think it shouldn't be to hard on my Blazer. Just have to be a little more creative on using the grinder. I think with bags you almost have to notch it. I am doing mine in 2 weeks. so I will keep you posted.
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
#20 |
n2tRUX WHAT SIZE ARE THOSE RIMS,I have a 78 2wd blazer and I'm putting 24" rims on it. I plan on a 8" c notch in the rear and Zing the frame in the front. Hopefuly I'll be starting that project here soon, will post pictures as soon as I do.
81 blazer 2wd tukin 30's 07 Jeep Grand Cherokee on 26's Tube chassis 5.3,dual T cases,54" boggers,steering rocks Dodge 3500 with some mods |
#21 | |
Happy to be here
![]() This is how the front will sit..... |
#22 |
its just $$$$$
I hate Ken
![]() j/k buddy |
#23 | |
Happy to be here
#24 | |
its just $$$$$
#25 |
Got L.E.D.s
Here's a pic of mine. Cpp notch with bumpstops, and dropped lower arms,
