Old 09-29-2004, 09:03 PM   #1
westcasey
'85 Chevy carb problems
I've got an '85 Chevy 3/4 ton 4x4. It has the same engine in it as the Corvettes had that year. I've had the dang thing in the shop several times because I don't know anything about carbs. It soots up the spark plugs really bad about a week after replacing them. I've had the carb rebuilt and adjusted 3 times by two completely differnt shops. It still does the same thing..... soots the plugs up and misses really bad. Can anyone help me out? NO BODY can seem to get this dang thing to run right. It ran perfect until one of my employees ran the thing out of oil and I had to replace the engine!!!
1987 GMC 1500 5.7L
1985 Chevy 3/4 4X4
2001 Chevy 2500 HD 4X4
2007 Chevy 3500 Duramax 4X4
westcasey is offline   Reply With Quote
Old 09-29-2004, 10:06 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
Not knowing for sure, but it sounds like you have a computer controlled carb on it since you say it's the same engines Corvettes had in 85. If this is the case, you will never get it to run right without the computer. What happened to the carb that was on the stock engine?
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 09-29-2004, 10:37 PM   #3
westcasey
This is the same carb. I don't think it is controlled by the computer. The only electrical wire running to it is going to the choke. It is the same engine as the corvettes that year; I checked that out with the local dealership.
1987 GMC 1500 5.7L
1985 Chevy 3/4 4X4
Old 09-29-2004, 11:26 PM   #4
76HighSierra
DAMN, I love Big Blocks!
76HighSierra's Avatar
Are you sure that you don't have an oil-fouling problem?
Marc Bona
Hobbs, New Mexico
1976 1/2 ton GMC High Sierra.
454 c.i.d./ TH400. *Soon to get a mild warming over.*
3.40 rear.
76HighSierra is offline   Reply With Quote
Old 09-30-2004, 08:56 AM   #5
westcasey
I don't know what you mean by an oil fouling problem.
1987 GMC 1500 5.7L
1985 Chevy 3/4 4X4
Old 09-30-2004, 10:09 AM   #6
76HighSierra
I mean are you sure it's not oil fouling the plugs instead of unburnt fuel?
Marc Bona
Hobbs, New Mexico
3.40 rear.
Old 09-30-2004, 12:51 PM   #7
westcasey
I don't know. What are some signs to look for? It blows black smoke, which I assume is from the dirty spark plugs not burning all the fuel off. What would cause the oil to foul the plugs?
1987 GMC 1500 5.7L
1985 Chevy 3/4 4X4
Old 09-30-2004, 02:16 PM   #8
hilbilly
I do everything twice, so what
hilbilly's Avatar
Location: To the Right. One may go as far to say WAY to the Right
Just a note, but are you sure the plugs are the correct heat range?
hilbilly is offline   Reply With Quote
Old 10-03-2004, 08:54 PM   #9
westcasey
1987 GMC 1500 5.7L
1985 Chevy 3/4 4X4
Old 10-03-2004, 09:19 PM   #10
1987SierraClassic
If it's blowing black smoke, it's running too rich....
Does it run poorly through the whole temperature range or just warm?
Is the replacement engine identical to the one you took out? If not, perhaps it's too much carb for it. The carb may be setup for the higher performance engine. You may have to re-jet the carb if that is the case...
Just a thought...
1987SierraClassic is offline   Reply With Quote
