09-30-2004, 12:00 AM | #1 |
Will a 77 1/2 ton fit under a 87 1/2 ton body?
Just aquired an 87 Chevy Wrangler for 200 bucks. Problem is the frame is broke on the passengers side and rusted badly. I have a good rolling chassis from a 1977 1/2 ton. Can I swap the drive line and body to this frame? I am in the process of taking the diff and front end of the 77 as these are going to be used on another project. Any info would be helpful. Any links also would be valuable. Great forum. Thanks.
1986 Silverado Short box fleet side. project 2005 VW Tiguan 4 Motion 1997 Blazer S10 4x4 1990 Chevy Silverado K1500 Extended long box |
09-30-2004, 07:58 AM | #2 |
yeller
I don't think you will encounter any problems, I believe the frames are pretty close to being identical. IIRC, the front and rear of the frames where the bumper brackets mount may be slightly different.
Maybe Chris (Capt Kaos) can chime in with his expertise.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
09-30-2004, 10:11 AM | #3 |
Thanks Bigblock, I appreciate the reply. I was hoping that that was what someone was going to say. I will await Capt Kaos's comments eagerly.
09-30-2004, 10:13 AM | #4 |
ive put an 81 cab with an 86 bed and bumper on a 76 frame and it all lined up except the bumper mounts which i wound up having to weld but its very easily done. I also had to run fuel lines to the other side of the truck to use a left mount tank as opposed to the right mount one very easily done also
so many trucks so little time!!! |
09-30-2004, 12:40 PM | #5 |
Thanks. Sounds like I have a maor project ahead, before the snow flys. Garage is used up with my son's 80 short box rebuild. He's away a school and can only work on it during brakes. Well I suppose I should get hte wrenches flying. Thanks again. Any other ideas appreciated.
