Old 09-30-2004, 10:56 AM   #1
72chey4x4
72 K/20 4x4 for sale in Northern Indiana
The body was pulled, frame cleaned up and coated. New 6" Skyjacker soft ride suspension with pitman arm changed, new shocks, and stainless extended brake lines. Runs on 35x14.5-15 Thornbirds mounted on Eaton rims. Truck is very solid the cab corners, rockers, and body mounts are all great. Currently in grey primer with minor body work required before paint... rear fender well patch pannels were proffesional installed and roughed in. The truck is powered by a healthy 350 with HEI ignition and transmits the power through a rebuilt turbo 350 and rebuilt NP205. I just completely rebuilt the Eaton Ho52 rear end it has 4.10 gear and a Detroit no-spin (l set the lash at .008). To my knowledge the front is an open diff dana 44... it has new hub bearings and seals which I installed just after rebuilding the rearend.
I have a new Goodmark drivers side door and good passengers door. Driver's side fender is goodmark. Could use a new passengers side fender, or you could clean up the one that's on it (no rust, but needs some attention).
I haven't had the truck very long, but have driven it about 500 miles since completing all major work to make sure there aren't any problems with it. I have every thing you need to finish the truck. I would suggest buying new wiring harnesses to eliminate a few shorts. The truck also has the remains of a dealer installed A/C kit.
I'm asking 5,000 obo.
72chey4x4 is offline   Reply With Quote
