Old 09-30-2004, 10:57 AM   #1
72chey4x4
72 K/20 4x4 for sale in Indiana
The body was pulled, frame cleaned up and coated. New 6" Skyjacker soft ride suspension with pitman arm changed, new shocks, and stainless extended brake lines. Runs on 35x14.5-15 Thornbirds mounted on Eaton rims. Truck is very solid the cab corners, rockers, and body mounts are all great. Currently in grey primer with minor body work required before paint... rear fender well patch pannels were proffesional installed and roughed in. The truck is powered by a healthy 350 with HEI ignition and transmits the power through a rebuilt turbo 350 and rebuilt NP205. I just completely rebuilt the Eaton Ho52 rear end it has 4.10 gear and a Detroit no-spin (l set the lash at .008). To my knowledge the front is an open diff dana 44... it has new hub bearings and seals which I installed just after rebuilding the rearend.
I have a new Goodmark drivers side door and good passengers door. Driver's side fender is goodmark. Could use a new passengers side fender, or you could clean up the one that's on it (no rust, but needs some attention).
I haven't had the truck very long, but have driven it about 500 miles since completing all major work to make sure there aren't any problems with it. I have every thing you need to finish the truck. I would suggest buying new wiring harnesses to eliminate a few shorts. The truck also has the remains of a dealer installed A/C kit.
I'm asking 5,000 obo.
72chey4x4 is offline   Reply With Quote
Old 09-30-2004, 01:16 PM   #2
1969K10
1969K10's Avatar
sounds like a nice truck... A little out of my price range, but where are you located?
1969K10 is offline   Reply With Quote
Old 09-30-2004, 01:37 PM   #3
72chey4x4
I'm about ten minutes south of Fort Wayne. The price is negotiable, but I've got about $5,000 in it at this point. Family, work, and other projects have motivated me to get rid of this project. I have to many extra items than I can list. New window felts, seals, door seals, a couple sets of tint glass, etc.
Old 10-01-2004, 09:09 PM   #4
mhohl
pictures?
mhohl is offline   Reply With Quote
Old 10-02-2004, 01:11 PM   #5
72chey4x4
I have about 35 pictures, and I'll try to post them, but my dial-up network takes forever. I've sent half of them via email to another site member last night and it took three emails and 45 minutes. send me your email address in a PM, and I'll send them to you.
Old 10-07-2004, 09:47 PM   #6
N242MUCH
72 chey4x4 if it does not work out that you sell the truck and you start to part it out i am interested in the lift , transmission and transfer case.
N242MUCH is offline   Reply With Quote
Old 10-13-2004, 10:30 AM   #7
72chey4x4
It's on Ebay
The truck is on Ebay... if you're interested here's the link.
http://cgi.ebay.com/ebaymotors/ws/eB...494309614&rd=1
