Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1947 - 1959 Chevrolet & GMC Pickups Part Board
Old 09-30-2004, 11:08 AM   #1
Ichevyluvr
Ichevyluvr's Avatar
Need v8 motor mounts
I am looking for v8 motor mounts.
The ones that attach to the block.
I have the rest.
59 sb stepside
all original except paint.
Opps this is old it has been changed.
Ichevyluvr is offline   Reply With Quote
Old 09-30-2004, 12:23 PM   #2
sdmahr
sdmahr's Avatar
They are about $7.00 at AutoZone or any other parts house.
sdmahr is offline   Reply With Quote
Old 10-02-2004, 12:18 AM   #3
Ichevyluvr
Ichevyluvr's Avatar
Sorry I meant the ones that mount on the front of the block. beside timing chain cover.
59 sb stepside
Old 10-02-2004, 10:09 AM   #4
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Like this one, yes?
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 10-02-2004, 07:34 PM   #5
john j
Denny how do you support the back of the engine? Are you running a manual or auto? I realize the powerglide has the mounts up front and i believe the manual's do also. If you use a t350 it mounts way back. Can you use a mount off the trans bell housing as if in a stock car? johnj
you laugh at me cause i'm different ;
i laugh at you cause you're the same
john j is offline   Reply With Quote
Old 10-02-2004, 08:59 PM   #6
Ichevyluvr
Ichevyluvr's Avatar
Yes! those are them what a sweet motor!!!!!
59 sb stepside
Old 10-03-2004, 01:20 AM   #7
DennyB
DennyB's Avatar
That is not my truck fellas. I probably should have stated that.
This truck was at a local show a couple weeks ago. I'm not sure what the rear mounts are. I sure someone will chime in for you though. Mine is sitting on a 71-72 chassis now so all the mounts are changed. I will be setting it on a 4wd or awd chassis.
The truck pictured was very clean with few modifications. With the air breather on the front of the intake it could be the stock 283. I'm not sure though.
This truck still had the sraight axle under it too.
Old 10-03-2004, 01:07 PM   #8
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Looks like the ones from a 55-57 car are the same also.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 10-03-2004, 02:19 PM   #9
john j
I bought mine from www.brotherstrucks.com you can also check them at www.chevyduty.com. Just remember you have to support the block at the back also. johnj
Old 10-03-2004, 09:56 PM   #10
ljbear
ljbear's Avatar
I may have a set, but won't be home until Monday morning. If that's not too late I'll check and let you know.
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
"Don't confuse enthusiasm with capability"
ljbear is offline   Reply With Quote
Old 10-05-2004, 09:49 PM   #11
rico_bob
"Treasure the Ride"
rico_bob's Avatar
DO NOT! I REPEAT --- DO NOT USE A 350 or 400 or 700R with the block mounted at the front! You will crack the tranny case or worse! You must support the trans at the bell area! My two cents worth! rico_bob
If you think you can you're right. If you think you can't you're still right.
Trucks: '56 SWB; '57 SWB; '63 C-10
Current projects: 1963 Long Fleetside for the wife!
'56 for the daughter.
Visit us at: www.ricos-rods-and-relics.com
rico_bob is offline   Reply With Quote
Old 10-05-2004, 11:03 PM   #12
Ichevyluvr
Ichevyluvr's Avatar
I have a bell housing out of a 58 pontiac with a v8.
I am keeping it manual. I was thinking a 5 speed out of a camaro but didn't know it would work or not.
59 sb stepside
Old 10-05-2004, 11:18 PM   #13
rico_bob
"Treasure the Ride"
rico_bob's Avatar
we sell the mounts if you still need them.
Old 10-05-2004, 11:58 PM   #14
Ichevyluvr
Ichevyluvr's Avatar
how much?
59 sb stepside
Old 10-06-2004, 06:18 PM   #15
rico_bob
"Treasure the Ride"
rico_bob's Avatar
Talking Motor Mounts
PM 'd you. rico
Old 10-06-2004, 07:32 PM   #16
BIGG BELLY
i have a bell housing out of my 55--has the bolt on style mounts if you need one
55 big window long bed
69 olds 98
check out my pics
photo albums
BIGG BELLY is offline   Reply With Quote
Old 10-07-2004, 12:27 AM   #17
Ichevyluvr
Ichevyluvr's Avatar
Thanks Bigg belly but no. I have one that will work.
And thanks to everyone who has helped me with this.
I got what i need today.
Thanks again everyone.
59 sb stepside
Old 10-07-2004, 11:22 PM   #18
rico_bob
"Treasure the Ride"
rico_bob's Avatar
you are welcome!
