Old 09-30-2004, 01:22 PM   #1
lock
Insert funny comment.
lock's Avatar
long tube v8 headers
What brand/model of long tube headers fit well on our trucks? Looking for 1 3/4 " tubes.
- Mark
-My Build Thread...
-68 C10, LT1 - Undergoing Frame off resto
-86 IROC-Z T72 turbo 355, M6
-70 Camaro
http://www.iroc-ss.com
lock is offline   Reply With Quote
Old 09-30-2004, 01:37 PM   #2
Primed67
Primed67's Avatar
I'm not sure who makes these headers but how much horsepower are you running? We sell Schoenfeld headers at work and have a chart to help us recommend sizes for customers. I checked and they don't make headers for the street nor our trucks. The chart shows:
1-5/8" 375-500 HP
1-3/4" 500-625 HP
1-7/8" 625-750 HP
2" 750-875 HP
Good luck finding some!
1969 Chevrolet SWB Stepside
1959 Chevrolet apache * Sold
1967 Prostreet Chevy SWB Fleetside *Sold
2014 1/2 ton Crew Cab Chevrolet 4x4
Primed67 is offline   Reply With Quote
Old 09-30-2004, 06:27 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
What engine do you have? Small block or big block? Auto or manual? (also, is it on the right mounts in the right location?)
Old 09-30-2004, 08:25 PM   #4
lock
lock's Avatar
Around 400 hp is where it will be. 1 5/8 could work or 1 3/4 since I have some thoughts of putting a power adder down the road. Alot of the impy and f-body guys go 1 3/4 so thats why I was leaning that way.
Longhorn; Its a smallblock 350 (LT1) with an auto. Using the stock mounts in the V6 location.
- Mark
-My Build Thread...
-70 Camaro
Old 09-30-2004, 08:35 PM   #5
Longhorn Man
I can say my hooker super comps fit nicely, but my small block is in the right spot...no idea about in the inline position. I think crazy longhorn may have the same headers but in the rear position...but I'm not 100% sure on that.
Old 09-30-2004, 09:08 PM   #6
crazy longhorn
Fabricate till you "puke"
Yup, I am in the rear position My sb is mounted in 6/250 spot. I run Hooker comps (1 5/8 tube, 2 1/2" collector). These headers will work for stick or auto, in either position.....auto trans should not cause too many issues either way, but a stick trans in I 6 position will take a few mods to fit the clutch linkage crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-30-2004, 09:46 PM   #7
ed455
Captain Ed
Hedman 1-3/4" fit my 66 which is a little tighter than the 67-72 trucks. The app for mine is 67-87 I believe.
ed455 is offline   Reply With Quote
Old 10-01-2004, 07:26 AM   #8
68C15
blood type; Retumbo
68C15's Avatar
heddman # 60990. I got mine used from another board member. 1 5/8 long tubes. my problem with them is that I going to go low & they come out below the frame. I will try to get some pics today @ work & post them so you can see just where the hang.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 10-01-2004, 05:58 PM   #9
lock
lock's Avatar
Thanks guys! Anyone know a good place to buy the Hooker's preferably coated?
- Mark
-My Build Thread...
-70 Camaro
Old 10-01-2004, 06:49 PM   #10
crazy longhorn
Try Summit or Jegs on the Hookers.....they get a bit pricey coated tho! They were about 140 painted , on the comps.....super comps will run a tad more, & figure to add about 2 bills for coated. Best of luck,crazyL
Old 10-01-2004, 07:53 PM   #11
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
Hooker Super Comps with Jet-Hot coating...You can purchase them directly from Jet-Hot...Just call them up.
lata
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
