Old 09-30-2004, 05:51 PM   #1
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Tilt interchangeablility
So what will work in these trucks? Will the one from a 75 1 ton van work? It looks nearly the same,the turnsignal plug is the same.The van also uses the same doorhandles and armrests,(if that matters).
Also how much trouble is it to change it over?
TIA
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 09-30-2004, 06:00 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Very likely. I know for sure bigger stuff like Frito Lay trucks and mail trucks used the same column for many years later than our trucks did.
My column is out of an 82 motorhome. Straight in swap for an easy, cheap tilt.
Old 09-30-2004, 06:22 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
As far as van tilts go, 72 - 81, and early 82's will come real close to bolting right in.
Old 09-30-2004, 07:55 PM   #4
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
my company has a 79 van that they are taking to the junk yard so i went to check it out........NO TILT i was a little perturbed
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 09-30-2004, 08:27 PM   #5
Brainchild
Brainchild's Avatar
Looks like I may pull this one out tomorrow and see if it will bolt up
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 10-10-2004, 10:13 PM   #6
purple gas
you may have to shorten your lower steering shaft.. If it's the colapsable kind,, take it out & smak the bottom part on a floor. I did it today, and it worked. ( some van columns are a bit longer than truck columns)
purple gas is offline   Reply With Quote
Old 10-10-2004, 10:39 PM   #7
Longhorn Man
That's right, if you have a 67 or 68, then you'll need an intermidiate shaft off a 69 - 72...then smack it on the floor like Mr Gas said, and slap it in. You'll also need to relocate the neutral safety switch...or just by pass it. IMO you almost have to be an idiot to accidently start it in gear.
Old 10-10-2004, 11:25 PM   #8
Brainchild
Brainchild's Avatar
Well being te procrastinator that I am,I still haven't pulled the thing out yet
I'll do it I swear I will
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
