Old 09-30-2004, 09:43 PM   #1
bozracer
wnc tvman
bozracer's Avatar
Fuel Gauge Problem
70 Longhorn,Fuel gauge stays on empty.If I disconnect the lead to the sending unit the gauge will peg on full.The truck came with aux.tank but has been removed.Bad sending unit? or connection problem?
Oz WNC
67 Short Fleet 350 4speed
70 Short Fleet 327 4speed
bozracer is offline   Reply With Quote
Old 10-01-2004, 01:50 AM   #2
longhorn71
longhorn71's Avatar
It Could Be The Gauge
longhorn71 is offline   Reply With Quote
Old 10-01-2004, 05:33 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Nope, the guage is doin what it is supposed to be doin. You either need a new float on the sending unit, or a new sending unit.
Old 10-01-2004, 12:11 PM   #4
Als454
If memory serves me right when you disconnect the lead to the sending unit the gauge should read full. If you ground the lead the gauge should read empty.
If I were to guess I would say that your float on your sending unit has a hole in it allowing it to fill with gas and causing it to always stay on the bottom of the tank, so your gauge reads empty.
I've had this problem on two of my trucks. It's an easy fix.
72 Chevy A/C P/B P/S Tilt
454 Engine 400 TCI Trans
C30 Frame C10 Suspension
Short Wheel Base (Dually)
Als454 is offline   Reply With Quote
Old 10-01-2004, 12:48 PM   #5
Old Dave
Is a bullfrog waterproof?
Old Dave's Avatar
Als454 and Longhorn Man are correct, the fuel gauge is working correctly. You've either got a float with a hole or a bad sending unit. The sending unit can be checked with an ohmeter after removal from the tank. When the tank is full the resistance of the sender should be about 90 ohms and when it's empty it should read close to 0 ohms. If the float has a hole in it either replace it or solder it shut if it's brass.
Good luck
"It is better to remain silent and be thought a fool, than to open one's mouth and remove all doubt."
Ben Franklin
1970 Chevy shortbed
2002 Harley Custom Chopper (Long sucker)
1998 K2500 5.7L 5-speed Longbed
1st two are My son's toys...they just live in my garage!
1997 GMC K1500 Suburban
1993 S-10 Blazer 4D (youngest son's daily driver)
2000 Dodge Ram 4WD Ext. Cab (5.9L)
Wife is a late year 1951
Old Dave is offline   Reply With Quote
