Blue 67
![]() Join Date: Apr 2004
Electric Choke
I have seen this has been discussed before but I couldn't find the previous threads, sorry to bring it up again. I need to know how to install the electric choke instead of manual one. I am changing the whole carb but I don't have any clue about electrick choke connection(s). Please explain it simple since this is the first time I am doing this. The wiring on the car is old one, I don't if it is original one though.
Thanks a lot. |
Run a 12v keyed wire to the red wire on the choke. Ground the black one on the choke housing.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
Blue 67
This might be a dum question but What will happen if I don't connect the choke at all?
Professional Grade
Be real rough to start, and keep running until it warms up... A motor likes a rich environment for starting in
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
#5 | |
Tim |
#6 | |
Professional Grade
![]() I wasn't thinkin, it'd start nice, and not wanna run later due to being too rich...
Make sure you use a true 12v source. If you hook the choke to the coil it will not be 12v (If the coil is wired correctly).
'70 K-20 San Diego, CA |
#8 | |
I miss this truck.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
#9 | |
Don't say "Oops!", Doctor
'Mutt 1968 CST LWB: R.I.P. 1967 Chevelle: TPI 454 beast 1967 C10 SWB: Claimed when Bumpster didn't put it on his list |
My Edelbrock 1904 instructions say 12v. The guy at the dealer I bought it from (I think Sallee Chevrolet) said to make sure I use 12v and not the coil.
Blue 67
For keyed 12 v wire, do I get it from fuse box?
I did mine to the fuse block. There should be a few open spots in the bulk-head connector. I just ran the wire with the coil loom to the bulk-head connector and used a two into one spade adapter on the back side of the fuse block. Should be able to get the terminals for the bulk-head connector at most auto parts stores.
