Old 10-01-2004, 09:33 PM   #1
ljbear
ljbear's Avatar
4x4 Chassis Parts, Mounts and Perches 4 Sale
Finally got this all stripped down. All chassis brackets and cross members are there except the Transmission x-member. Spring perches, motor cradle, body mounts are all there. Let me know what you need. Tub is all gone nothing left. These parts will work on a truck or blazer, except the rear cab mounts and rocker box ends, which are blazer parts.
Rocker Box End Caps, both in great shape, with most of the original fasteners. Sold (TeamHarvey)
Front Spring perches, forward pair with Radiator support base SOLD (Bob in Chico)
Front Spring Perch, Rear Swivels SOLD (Bob in Chico)
Rear Spring Perches, Forward Spring mounts, SOLD (Jims70)
Rear Spring Perches, Rear Spring Swivels, SOLD (norville)
Rear Upper Shock Mounts, $15 Pair
Rear Bump Stop Brackets. $15 Pair
Front Cab Mounts, $15 Pair
Rear Cab Mounts, Blazer only, $15 Pair
Blazer Bed Mounts, 4 pieces, $20
Front Crossmember, $20
V8 Engine Cradle, Sold (OhioChevy)
Steering Box Reinforcement Plate, $25
Transfer Case Torque Mount, Sold (Cheyenne 10)
Intermediate Cross Member, Sold (Zoomy)
Rear Cross Member, $15
All prices + shipping.
I do have a PayPal account. I'll mark items sold and note to who, if you don't wan't your name noted please let me know, just my way of keeping track of what's going where.
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
"Don't confuse enthusiasm with capability"
ljbear is offline   Reply With Quote
Old 10-01-2004, 10:00 PM   #2
norville
PM sent "Rear Spring Perches, Rear Spring Swivels, $20 Pair"
norville
1986 C10 Scottsdale
5.3, TH400
norville is offline   Reply With Quote
Old 10-02-2004, 02:21 AM   #3
ZOOMY
K20 x-member
I need the big crossmember for a K20. It's the one that is near the front set of rear spring perches. Would that be the same as a Blazer ? Is the tube grill still available ? How much for the alternator & adjuster bracket ? Also the air cleaner if it's for a 4 barrel.It looks fairly new. How about those mirror mounts ? Do you also have the backing plates for them ?......Thanks...........Zoomy
ZOOMY is offline   Reply With Quote
Old 10-02-2004, 04:55 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Hey Larry, forgot all about your 4x4 frame. I'll take those front spring hangers for the rear springs.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 10-02-2004, 07:06 AM   #5
CUSTOM/10
CUSTOM/10's Avatar
Cross member
I need the cross member that goes under the trans/tranfer case adapter. One that came from a blazer/truck that had a np205 in it.
I also could use a rear cab mount for a "TRUCK" if you have any kicking around.
Gary
CUSTOM/10 is offline   Reply With Quote
Old 10-02-2004, 09:43 AM   #6
ljbear
ljbear's Avatar
Zoomy, I'm not sure. If you can get a dimension I'll check it, these are the same as the K10's so I figured they would be the same. I'll pm on the rest of the parts.
Jims70GMC, rear fronts are yours. PM your address with a phone #, I'll get back to you on the shipping.
Custom 10, that cross member is gone and no truck rear cab mounts right now. I might be parting another blazer, so I could have a cross member available. If you can wait let me know, I'll put your name on it.
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
Old 10-02-2004, 10:34 AM   #7
CUSTOM/10
CUSTOM/10's Avatar
Cross member
Put my name on the next cross member that you get, and in the mean time let me know what the shipping would be to NH 03873 .
Gary
Old 10-02-2004, 10:37 AM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
pm sent.
Old 10-03-2004, 09:11 AM   #9
ljbear
ljbear's Avatar
ttt
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
Old 10-05-2004, 02:31 AM   #10
ZOOMY
Pm
You have a PM on some parts.
Old 10-05-2004, 02:00 PM   #11
ljbear
ljbear's Avatar
Picture for Zoomy
Zoomy here's the cross member. It measures 8 1/2" wide, and would fit between 5" frame rails. Sent you a PM on the other stuff.
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
Old 10-07-2004, 12:07 AM   #12
ljbear
ljbear's Avatar
Ttt
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
Old 10-07-2004, 08:59 AM   #13
Blue_71
Bloo
Blue_71's Avatar
did it happen to have about a 4 inch lift? if it did, what would you want for the front springs and drop steering arm?
Blue_71 is offline   Reply With Quote
Old 10-07-2004, 11:12 AM   #14
ljbear
ljbear's Avatar
Sorry, No 4" lift or arm. May be able to get a set of 2 -2 1/2" springs for you if I end up parting the blazer I'm trying to sell
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
