Old 10-01-2004, 10:20 PM   #1
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Blazer Bed Rail Caps
Found this listing on-line. I called the guy and they are diamond plate caps that cover the bedrail on a Blazer when the top is off. Since I run with either the hard top or the soft top on, I don't have a use for them.
1967-1972 BLAZER full pop top, rear bed, diamond plate, top dress caps, like new, $50. call Everett 360-658-8676 - Marysville, WA
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 10-02-2004, 04:19 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I HAVE BEEN WANTING SOME, I WANT MINE TO BOLT ON LIKE THE TOP
FROM THE UNDER SIDE, PAINTED TO MATCH, AND SLOPED FROM ZERO
DEGREES IN THE BACK TO EVEN WITH THE TOP OF THE DOOR, KINDA
LIKE A FLUSH MOUNTED TONNEU COVER FOR THE RAILS THEMSELVES.
ATTACHED A VERY CRUDE AND QUICK VERSION OF IT, WDYT
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 10-02-2004, 04:30 PM   #3
bouncytruck
SKINNY TIRES RULE!
I think these are just bent diamond plate that covers the top of the bed rail, not something to compensate for the height difference between the door and the bed rail. I have seen a 2wd blazer that had something similar to what you are describing, but they put a spoiler over the tailgate.
I'd think you could make somehthing out of wood and then cover it in fiberglass to do what your talking about.
bouncytruck 1972 K5
Old 10-02-2004, 04:47 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I Knew What You Were Talking About, One Of The Guys At Work Is
Gonna Try Making Me A Couple Out Of Aluminum, Then I Can Tap Em
From The Underside To Use The Top Hold Down Holes And Bolts, I
Might Not Paint Em, Thinking About Anodizing Them, Who Knows.
