Old 10-01-2004, 10:21 PM   #1
yfs200p
yfs200p's Avatar
Mirror flapping in the breeze
My passenger mirror is really loose. I move it to exactly where i want it, then when i shut the door and the damn thing moves in, so i cant see out of it. Is there a way to tighten these that doesnt involve taking the door panels off? I guess it's my own fault, because i already had the door panels off once, and never tightened them..... thanks...NICK
'72 K10 SWB Fleetside. Avocado Highlander Frame Off Re-Creation
'72 K5 CST Highlander Project
'24 2500HD Z71 LTZ Duramax
'22 Tahoe Premier Duramax
‘03 2500HD ECSB 6.0L
yfs200p is offline   Reply With Quote
Old 10-02-2004, 12:08 AM   #2
Russell
Professional Grade
Russell's Avatar
Mine does that too, it seems the grommet that is suppost to stiffen them up wears out / dry rots after a while...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-02-2004, 04:51 AM   #3
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
There is a torx bit screw on the bottom of the mirror housing. Unscrew it and slid the housing up and see there might be something to tighten them up. Its been forever ago that I was in one and I cant remember what all is in there. But I thought I seen something in there to deal with tightening them up.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 10-02-2004, 07:27 AM   #4
76bonanza
76bonanza's Avatar
there are two set screws under the cover you can thighten that might help.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
