Old 10-02-2004, 01:49 AM   #1
ocbaud
Garage Queen Material
steering is borked, help me fix it.
even after getting an alignment, my steering is still not right. it just doesnt feel like it should, and it kinda scares me
what steering parts do i need to replace that should help out? the tierod ends and ball joints will be replaced later when i rebuild the front end, but i want to replace some of the other stuff now.
idler arm?
pitman arm?
when i first lowered the truck, the place that aligned it didnt warrenty it becasue it had warn front end parts. looking at it now and then, it looks like the steering is whats worn out on it.
the steering feels really looser than it should be and its like the wheel is gonna fall off(not really, but i picture it happening)
ocbaud is offline   Reply With Quote
Old 10-02-2004, 08:36 AM   #2
low 84
low 84's Avatar
most likley the majority of your steering parts need replaced. when you put the 17's on it probly just amplified how you feel it in the steering wheel
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 10-02-2004, 08:50 AM   #3
88Jimmy4x4
88Jimmy4x4's Avatar
Could just be your not used to the new tires/wheels. Going from steelies to aluminum feels different...the new wheels are much lighter and the new tread pattern will make it feel different too. Hard to diagnose or make recommendations over the keyboard
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 10-02-2004, 09:01 AM   #4
ocbaud
actually, my old wheels were alum too.
and my new ones are quite a bit heavier also.
and it only started having crappy steering after i swapped spindles
Old 10-02-2004, 04:53 PM   #5
cliffsta
Stepsides RULE
cliffsta's Avatar
well, you just said it, you swapped spindles and have bigger wheels. I don't remeber off hand how much bigger your total circumference of your wheels and tires is, but if its much bigger, then steering angles and what not changes. And lowering the truck even 1 inch more than it was will change the AoA.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 10-02-2004, 06:04 PM   #6
ocbaud
the tires are actually 1" shorter.
Old 10-02-2004, 07:36 PM   #7
low 84
low 84's Avatar
everything probly needs replaced under there and your better off just buying the kit and doing it all at the same time. replacing 2 or 3 out of 10 worn out parts isn't going to do you any good.
i did my steering box, pitman arm, idler arm, inner and outer tie rods, upper and lower ball joints, upper and lower control arm bushings. chances are you need most of the same stuff replaced.
'05 1500 Crew Cab
RIP
Old 10-02-2004, 09:21 PM   #8
85Silveradoin04
Sorry for being off topic but --Ocbaud, did you convert the rear to disc brakes or are they drums still?
85Silveradoin04 is offline   Reply With Quote
Old 10-02-2004, 09:25 PM   #9
76HighSierra
DAMN, I love Big Blocks!
76HighSierra's Avatar
idler arm?
pitman arm?
That's the alignment place's fault, anyways. They shouldn't have lined it up the first time, if it had worn front end parts. I don't know what the laws are in OK, but here in NM, it's illegal for a shop to line up a vehicle with worn front end parts.
Marc Bona
Hobbs, New Mexico
1976 1/2 ton GMC High Sierra.
454 c.i.d./ TH400. *Soon to get a mild warming over.*
3.40 rear.
76HighSierra is offline   Reply With Quote
