Old 10-02-2004, 06:36 AM   #1
vtblazer
vtblazer's Avatar
Who Sells Air Shocks?
Trying to find some air shocks for my 71 2wd, coil sprung truck and can't find any, they are listed for leaf spring suspension but not for coils. Who sells 'em for a coil rear???
I want to be able to tow with this truck and need to be able to "pump up" the rear suspension when thing's get heavy.
vtblazer is offline   Reply With Quote
Old 10-02-2004, 06:41 AM   #2
rage'nrat638
rage'nrat638's Avatar
does it have the heavy duth rear springs or the light duty?????
the heavy duty ....the coils are evenly spaced...
the light duty are tight in the center and wider on each end
http://cgi.msn.ebay.com/ebaymotors/w...e=STRK:MESE:IT
rage'nrat638 is offline   Reply With Quote
Old 10-02-2004, 08:05 AM   #3
vtblazer
vtblazer's Avatar
Springs
Good to know...mine are light duty.
Wanna sell me those you have listed on e-bay or should I just bid on them?
PM sent.
Old 10-02-2004, 10:59 AM   #4
1972C10
1972C10's Avatar
www.autozone.com They sell gabriels.
1972C10 is offline   Reply With Quote
Old 10-02-2004, 11:19 AM   #5
flip66
flip66's Avatar
might also try load lever shocks they have springs around the shock little rough ridding when not loaded though
flip66 is offline   Reply With Quote
Old 10-02-2004, 01:25 PM   #6
OLDROCK&ROLLER
OLDROCK&ROLLER's Avatar
Advance auto parts have them. Monroes sp
72 CHEYENNE 10 SUPER
468/400/3.73
OLDROCK&ROLLER is offline   Reply With Quote
Old 10-02-2004, 02:23 PM   #7
StingRay
StingRay's Avatar
The stock shock brackets aren't strong enough to handle shocks by themselves. Adding suspension load to them is asking for trouble. I have had to replace lower shock brackets a couple of times on my truck in the last dozen years.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 10-02-2004, 02:55 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The man does have a valid point....
maybe those airbags that go in the middle of the coil springs would be better.
Old 10-02-2004, 07:02 PM   #9
vtblazer
vtblazer's Avatar
Weak Link...
Hadn't thought about that...thanks for the input.
I think I'll be trying the heavy duty springs I just purchased from rage'nrat638
first and see how it handles the loads from there. Next would be the air bags in the coils. (thanks TX Firefighter)
Gotta luv the board...ask and you shall receive.
Old 10-02-2004, 09:26 PM   #10
GSFMECH
On the road
GSFMECH's Avatar
Another thing that works pretty good if you can find them is the optional overload. It is an eliptical leaf spring that has a bracket and bolts in at the rear of the frame. There is a plate that sandwich's in between the rear end housing and trailing arm and has a rubber bumper. When the truck drops the spring makes contact with the bumper. I used to have a set and they worked pretty good.
Mike
GSFMECH is offline   Reply With Quote
Old 10-02-2004, 10:03 PM   #11
rage'nrat638
Thumbs up Hd Rear Springs....
THEY WILL BE GETTING DROPPED OFF AT FED-X TOMARROW MY FRIEND.....
FELL FREE TO CHECK MY STORE.....I NEED CASH....
I HAVE TON'S OF PARTS LISTED.......
http://stores.ebay.com/RAGENRAT638S-...RUCKPARTS-MORE
Old 10-03-2004, 08:36 AM   #12
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I think Kingparts has a set of those overload springs.He did a couple weeks ago.You might PM him if you decide to go that way.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
