![]() Join Date: Jun 2002
Removing rocker boxes
What's the best way to remove the rocker box from the inside channel? It would make replacing my panels easier and give me the chance to evaluate rust better. It looks like there are welds inside the oblong holes? Grind 'em, chisel, or both?
Thanks, Roger
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
Member since 2000
there's some welds on the front side too, towards the wheel well. Grind carefully cause you don't want to cut into the support brace. Goodluck
GO VOLS!
Just took out my driver's side box. Its a lot easier if you have to cut your floor pan out. I used a combination of grinding w/ a 3" air cutoff tool, reciprocating saw to cut the welds where I could get inbetween the support brace and box, and a sharp chisel. Good luck.
http://1972blazer.shutterfly.com/<= blazer build pics It's called golf because all the other four letter words were taken. It's easier to ask for forgiveness than for permission. |
If they are spot welds, I believe Eastwood has a tool for cutting them.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
They're not spot welds... more like stitch welds. I had good luck getting mine off with a 4" grinder and an air chisel. I had to jack the front of the tub off of the frame somewhat to get access to everything.
Thanks guys, sounds like fun...
Rg
The Blazer King
Make sure the top is on or you put in some bracing to hold the body rigid.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
