Old 04-03-2002, 05:04 PM   #1
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Post Is there such thing as a 12in clutch with a 26 spline input?
I can't seem to find one.
67
Ben
67 Fleetside Custom C-10
SBC 350 .030 9:1 comp.
Comp Cams Extreme Energy XE256H-10
Carter AFB 600
Edlebrock performer intake
Screw in rocker studs
Oversize valves
Scat 350 crank
Everything balanced within one gram.
Marine grade plywood bed(looks awsome)
67Fleetsidedream is offline   Reply With Quote
Old 04-03-2002, 06:28 PM   #2
MJN
MJN's Avatar
Post
I have a 12 inch clutch in my '74 but I think the input is just a 10 spline. What tranny do you have?
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 04-04-2002, 10:27 AM   #3
67Fleetsidedream
Post
Well, I am wanting a Richmond ROD 6 speed transmission. They offer more gear ratios with a 26 spline input shaft. I have a 12in with 10 splines. I want to keep the 12in clutch. Does Centerforce make one?
67
Ben
Old 04-04-2002, 10:30 AM   #4
69 longhorn
Post
If you are looking at a good clutch like Centerforce,I would just go with the 11" clutch. The same flywheel will work.....69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-04-2002, 12:26 PM   #5
Blazer1970
Blazer1970's Avatar
Post
There are listings for 12" GM clutch discs with the 1 1/8" 26 spline hub. I am looking at McLeod listings in the PAW catalog, and that combo is there. I would think that most clutch manufacturers would make it.
Blazer1970 is offline   Reply With Quote
Old 04-05-2002, 06:10 PM   #6
Project1970
14.1 @ 96MPH
Project1970's Avatar
Post
Just wondering - why are you going with the ROD instead of the Borg-Warner T-56? The latter seems to be about half the price of a ROD...
Project 1970 - soon to be seen at http://milhouse.treylis.org:81/
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 04-06-2002, 11:14 AM   #7
67Fleetsidedream
Post
I want to be able to pick the gear ratios that I want. The t5 and t56 take alot of modifications to install. The ROD is a direct bolt up.
I have read the the t5 and the t56 are vary weak trannies. They were designed for the factory application and nothing else. I want something that is tough.
67
Ben
Old 04-06-2002, 07:09 PM   #8
69 longhorn
Post
You have the right idea 67,the richmond 6spd should be pretty much bullet proof! I would love to go that route in the longhorn,but spent it pretty hard on the 383. Guess the hydro will do for now!......69 longhorn
