Old 10-02-2004, 10:49 PM   #1
Huskerboy2
Removing Blazer Bedsides
How hard is it to remove the bedsides from a Blazer? If you do it, does the bed floor come out easily also and the "cab" portion as well. I think I saw a bunch of pictures from GeeEmm one time that showed this pretty well.
If you break a Blazer body down like that, are you in danger of not being able to get it lined up properly again after disassembly???
'72 Chevy Blazer
Huskerboy2 is offline   Reply With Quote
Old 10-03-2004, 01:08 AM   #2
Gee_Emm
The bedside has some welds holding it on at the front and the back, nothing major. Other then that is is bolted on, you would have to take the end cap off of the rocker box to get to some of the bolts and of course the rocker would have to come off. The bedfloor would just come off with the bedsides gone, it is just bolted down. As for alignment as long as you are careful and check your work periodically during the rebuild it should work, you will have to play with shims on the body mounts to get the doors to line up. I had mine all together and it fit ok and half of my Jimmy is made from a pickup truck so if you are using Blazer parts things should be a breeze. If you are doing work on just the cab and the rocker boxes arent solid you may want to reinforce it like did, I just used old bed rails and tacked them to the dash and floor.
Gee_Emm is offline   Reply With Quote
Old 10-03-2004, 02:09 PM   #3
WyoChevyJoe
Hey Gee Emm, Thanks for the info & pic.
Even though I'm currently selling my 71 Blazer to fix up my 72 Burb (which will have Woodie panels on it someday), I want to eventually make a phantom Woodie rod out of a 69-72 Blazer 2X. Your pic & info gives me good info without having to experiment first.
Thanks for sharing.
WyoChevyJoe
72 Suburban - future Woodie Rod - Ex Forest Service C20
2-72 C10s - 1 to be fixed up & 1 for parts
71 Blazer K5 - For Sale still
70 C10 - Rusty hauler
Dang, it's summer already
WyoChevyJoe is offline   Reply With Quote
Old 10-03-2004, 08:44 PM   #4
Huskerboy2
Thanks GeeEmm. I knew you would have the answer. So, it looks like the rear door pillar or rear door jam stays with the "cab" portion of the tub. I guess the exterior skin of the bedsides just wrap around the outer edge of that rear door pillar and it's spot welded down the seam. Does the bedside separate pretty easily from that rear door jam just by cutting out those spotwelds, getting all the bolts out and separating the panels?
'72 Chevy Blazer
Old 10-04-2004, 12:29 PM   #5
Gee_Emm
The pillar would come off with the bedside, I have to replace the door pillars on mine thats why it is sitting there all by itself,
Old 10-04-2004, 09:15 PM   #6
Trifelynn
Trifelynn's Avatar
Gee Emm...it looks like I am going to be following in your footsteps, with what I am going to do...sorry for the duplicate thread, about removing my blazer body...
you say most of yours is made from pickups parts...did you happen to use truck bedsides? I am looking into a full bed for 550...The one on the parts board. '67, no markers...but, I don't know how much fab needs to be done, to fit the truck sides on the blazer sides...any suggestions?
Always looking for a 2wd blazer
Trifelynn is offline   Reply With Quote
Old 10-04-2004, 11:21 PM   #7
Gee_Emm
I used a pickup cab and a LWB pickup floor. You can use SWB bedsides but you will have to cut down the front and fold the metal over which isnt an easy thing to do. It took me quite a while to get this patch formed to perfection nevermind doing two whole sides. But unless you can find a couple decent Blazer bedsides that is the way to go. If you haven't seen it already check out my progress thread for my Jimmy, it will give you a better idea of the inner structure of how the sheet metal is.
http://67-72chevytrucks.com/vboard/s...d.php3?t=59412
Old 10-05-2004, 07:07 AM   #8
Trifelynn
Trifelynn's Avatar
You are a plethera of information...thank you kindly...
I don't care what South Park says....Canadians ARE good people..hehe
