Old 10-03-2004, 11:22 AM   #1
mr mike
mr mike's Avatar
lower a 4x4 1987 suburban
. I just got a 1987 suburban 1500 4x4 rebuilt motor and trans with 60k on them got it for a $1,000.00 not bad. well I would like to lower it so this is what I need help with can I lower a 4x4 and if I can how far I would like to do a 4 to 5 drop in the front so thanks for the help (I posted this in the 73-87 bord but then I saw the 73-91 suburbans spot so some help thanks
can I pull off the frount drive shaft or put blocks under it I do not know thanks
mr mike is offline   Reply With Quote
Old 10-03-2004, 12:05 PM   #2
desertchevy
Sell it and buy a 2wd. You will have to flip the axles under the springs and you're probably looking at at least a 6" drop I would think.
2006 Dodge Quad Cab 4X4
2001 Chevy Impala
2006 Corvette
2009 Fusion
1964 Toyota Landcruiser FJ45 Wagon
desertchevy is offline   Reply With Quote
Old 10-03-2004, 12:42 PM   #3
mr mike
mr mike's Avatar
how will that work the axal look's like it was made to sit on top.but 6'" is ok with me
Old 10-03-2004, 05:01 PM   #4
somery
you should raise it instead since you got a 4x4...i'll trade you my 2wd! you need big wheels for your burb...
somery is offline   Reply With Quote
Old 10-06-2004, 12:11 PM   #5
Prerunner1982
Prerunner1982's Avatar
you can only lower the front so far as the diff will come in contact with your oil pan, the rear can be lowered like any other truck. they do make flip kits to put the axle over the springs... but the front can only be lowered a few inches... not 6... you would have sever clearance and steering issues...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
