HELP !!! Ball Joint Install / See Picture
I am rebuilding suspension on my 72 C10 Burb and am fitting the upper control arms with new ball joints at this moment. The ball joint came packaged with a rubber dust boot mounted to a steel plate. Do I drop the boot in through the top of the control arm or secure it from below? It is a really tight fit from the top and I cant seem to cram it through the hole. Maybe if I lube it? Any thoughts or experience? See picture below.
72 C10 Burb 350 700R4 70 C20 LWB 350 Crate TH400 68 Chevelle Last edited by rn2fine; 10-03-2004 at 01:29 PM. |
Fabricate till you "puke"
Balljoint on the top of the a arm, & the boot on the bottom of the a arm
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Longhorn is right
.......and....... get those parts off your wife's bedspread and back outside before she twists off on you.
Thanks guys. As always I appreciate your help.
Jeff
72 C10 Burb 350 700R4 70 C20 LWB 350 Crate TH400 68 Chevelle |
