10-03-2004, 07:43 PM | #1 |
Active Member
Leds won't flash
I've had the rear leds and side marker leds for some time but today I tried yellow 1157 leds in the front and now none of the lights will flash if the parking lights or headlights are on. I have an electronic flasher and checked all the grounds. I know that the leds don't draw as much current and if I put incandescent bulbs back in the front turn/parking everything works- but I would like to use leds all around. Isn't there something in the newer cars and trucks they use when there are leds all around?
Thanks much!
68 short fleet 383 stroker, 700r4 373:1 posi 72 GMC 3/4 ton- weekly driver 700r4 351;1 posi |
10-03-2004, 07:46 PM | #2 |
its all about the +6 inches
Odd, with the electronic flasher, it should blink even if it is just one LED and nothing else.
What brand of flasher is it? |
10-03-2004, 09:00 PM | #3 |
Active Member
It was a genuine "Pep Boys" Andy, so I guess its a cheap one. I was thinking of switching it out, they're cheap enough, I suppose.
10-03-2004, 10:53 PM | #4 |
I know the NAPA ones are pretty good, I think they are kinda pricey though.
But on my 69, it has LEDs in the back, and old bulbs up front. When I removed the front bulbs, it would still blink on just the LED load. |
10-03-2004, 11:24 PM | #5 |
Active Member
We have a napa here, I' ll give it a shot.I sure hate to give up and turn it over to the auto electric shop, but I'm starting to get baffled. I thought there was a post about this some time ago, saying something about 'rzengineerining?" having a setup for all led lights to replace the electronic flasher.Back to the drawing board I guess. Thanks Andy. Glad you're back on the board helping the rest of us.
10-03-2004, 11:39 PM | #6 |
Got Light Emitting Diode?
hey curbie do you have a fleet side? do you have the 1157 led bulbs or a true led conversion in the back? i am thinking about making my own and was wondering how many leds the conversions consisted of. thanks(sorry for high jacking, hope the new flasher works for you)
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
10-03-2004, 11:48 PM | #7 |
67-72 Addict!
When I installed my LED's, I used a EL-12 Flasher.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
10-04-2004, 12:08 AM | #8 |
Active Member
68w- yes, its a fleetside, I got the leds from a board member that was making them before he started making the for ECE. I think they are 120 leds each side but i will count them in the morning for you.
70c10- where idi you get your el-12 flasher? Andy- the brand is TS- made in USA Thanks guys
10-04-2004, 12:13 AM | #9 |
I'll have to look at mine tomorow and give you a name/part number.
10-04-2004, 12:33 AM | #10 |
Active Member
Thanks Andy
10-04-2004, 12:54 AM | #11 |
67-72 Addict!
I got it at Advance Auto Parts
10-04-2004, 10:05 AM | #12 |
Active Member
68wsbc406-
I counted the leds this morning, I was way off on my guess. There are 168 leds and the board measures 2 3/8" wide and 8" tall Hope it helps My neighbor in Perry Hall- thanks & have a good weekend Curbie
10-04-2004, 11:46 AM | #13 |
Where ae y'all getting your LED tail lights, etc?
When I went with all LED's on my motorcycle, I had to add a resistor to the circuit. Basically, the LED's had so little draw on the circuit that the flasher couldn't sense and flash. |
10-04-2004, 01:09 PM | #14 | |
Kinda butch, but pretty cheap compaired to the kits you can buy. |
10-04-2004, 04:49 PM | #15 |
Thanks. I may hunt down the replacement lenses.
10-04-2004, 09:16 PM | #16 | |
Good luck in finding the little electric gremlin.
My girlfriend caught me cheatin on her with another woman and now she's threatening to tell my wife! ____________________________________ 71 Chevy lwb Rough and Ready Baby!! |
10-06-2004, 02:25 PM | #17 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Grendel is right.
LED's DO NOT draw enough amps to work with a reg flasher,even an electronic flasher didn't work for me. You need the reg bulbs or as sugested use a resistor to help activate the flasher.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
10-06-2004, 03:11 PM | #18 |
Active Member
Thanks for all the replies-
Anyone know what resistor to get or where it should go?
10-06-2004, 07:50 PM | #19 |
You might try www.radiantz.com . They specialize in LEDs for motorcycles but since both are twelve volt and since a tailight is a tail light and a blinker a blinker they probably have a fix for you. If not, I bet they point you in the right direction. Good luck.
10-07-2004, 12:46 PM | #20 |
Active Member
Update
I just spoke to radiantz(thanks Nixon) they were very helpful. I ordered thier "flasher". As soon as I get it wired in I'll get get back to you all or do a FAQ. The leds I bought for the front have several yellow leds facing straight ahead,and about four small leds facing back into the housing. I painted the housing interior with chrome paint to bounce more light. If I can make it all work out, it should be nice setup.Thanks for all the help Curbie
