Old 10-03-2004, 07:57 PM   #1
weekender
If it don't fit, force it.
I broke my passenger side window on my 83 dually so I got one out of my 79 half ton and put it in, well it fits except now I can't hardly roll up the darn window. It's real tight, it will go up with alot of force. I wander if the 79 is a little wider. Does anyone know?
weekender is offline   Reply With Quote
Old 10-03-2004, 08:28 PM   #2
Russell
Professional Grade
Russell's Avatar
I think that the 73-80 doors are different from the 81-87 trucks, so that may explain your problems.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-03-2004, 09:30 PM   #3
1987SierraClassic
I thought the doors changed in 77? If so, you should be alright on the window. Are any of the rubber pieces binding? I've never changed one, but I'd try peeling out the window channel rubber and then try the window. If it is still hard to roll up/down then it may be binding in the window regulator. Perhaps a glass shop that's done a lot of them may offer some advice...
1987SierraClassic is offline   Reply With Quote
Old 10-04-2004, 06:18 PM   #4
cliffsta
Stepsides RULE
cliffsta's Avatar
well, yes and know on glass. In 81, GM used lighter glass all around to shave weight, so its possible the window is wider. BUT the door shells are the same 73-87 im pretty sure.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 10-04-2004, 09:57 PM   #5
weekender
Thanks for your feedback, I had it all out when I painted the truck. I replaced all the rubber molding and felt, I will try adjusting the wing sometime this week. I think I will just take it all apart and check it all out.
Old 10-04-2004, 10:34 PM   #6
cliffsta
Stepsides RULE
cliffsta's Avatar
AHHHH you just answered your question. changing felt and rubber stiffens the action of the windows until the new material is broken in. Even just replacing the plastic door channel on the door panel stiffens the action.
