![]() Join Date: Jul 2004
I need a little help.....
Here are a few pics of the tilt column I have. I need to rebuild it but first I want to make sure of what I have. Previous owner has no clue and the wheel looks to me to be off a mid-eighties truck. I know you guys can tell right off what it is so any help would be great.
Thanks in advance, Bret |
It is a 71-72 truck column or a early 70's van column. Need a picture of it on the outside of the firewall to confirm.
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
Thanks Bill......here you go
Looks like a van column to me. Bret I will get your knobs shipped monday. I got a pair of Non CST radio knobs yesterday, same deal as before. If you want the non CST ones let me know ok Harold.
Yes, that is a van tilt, as far as rebuild parts all of your replaceable parts are the same as the 71-72, just the shaft length and location of neutral safty switch is different.
You guys are great ! I have met so many good people on here in such a short time.
Bret |
One last question.........where would I find the "internal" parts ? The shifter hangs up at times and there is something plastic that is slowly breaking apart and falling out in pieces when forced into gear.
Bill, it is a little hard to tell by your picture but appears to be 81-87 range
huh ???
I'd say 84-87. Colums up to 83 had the dimmer switch on the floor...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
#11 | |
its all about the +6 inches
The column at the top of the post looks to be ab early van tilt...72 - 75 or so. The shifter is long like the stock ones on our trucks. The later ones have a shorter shifter that are nicer when you update to a smaller wheel.
The second tilt pic the 84 to 87-ish, (I think later than that is possible) would not be an easy swap into our trucks. you'll have an ignition switch and wiper switch ans high beam switch to figure out the wireing to, plus you'd have to modify the bottom of the dash due to the later columns larger diameter. Quote:
thanks guys
#13 |
Weekend Warrior
is it just the length of the shaft that is different on the van tilt...i looks to be alot longer than the truck ones...??
and the nuetral saftey switch relocation??
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
